【Abstract】 Objective To determine the β,β’-dimethylacrylalkannin in lithospermum erythrorhizon, compare the extractingrate of different solvents to β,β’-dimethylacrylalkannin and study the stability of standard β,β’-dimethylacrylalkanninsolution of alcohol. Methods A HPLC method was used to determine the β,β’-dimethylacrylalkannin. Dikma Diamonsil C18chromatogram column(200 mm×4.6 mm, 5μm) was used, Acetonitrile-water-Formic acid(700:300:0.5) as mobile phase, flowrate at 1mL·min-1, detection wavelength at ... 更多还原 【关键词】 紫草; β,β’-二甲基丙烯酰阿卡宁; 提取率; 高效液相色语法; 稳定性; 【Key words】 Lithospermum erythrorhizon; β,β’- dimethylacrylalkannin; Extracting rate; HPLC; Stability;
