【Author】 XU Wei Min 1, ZHANG Hui 1, YUAN Wei Fang 2, WANG Yi Ting 3, YU Chen 1 (1.Shanghai Xuhui District Central Hospital; 2. Shanghai Institute of Materia Medica, Academia Sinica, Shanghai 200031; 3.Shanghai Institute for Drug Control, Shanghai 20
【Abstract】 A HPLC method with fluorescence detection for the determination of α 2,5 dimethoxyphenyl β aminoethanol hydrochloride in serum was established. The serum sample was treated with solid phase extract. A Diamonsil C 18 column was used, with the mobile phase of methanol 0.1% trifluoroacetic acid solution (28∶72). The excitation and emission wavelength were 288 and 328 nm, respectively. Methoxamini was used as internal standard. The calibration curve was linear in the range of 0.5~32 ng/ml ( r =0.999... 更多还原 【关键词】 米多君; 脱甘氨酸米多君; 血清; HPLC-FLU; 测定; 【Key words】 midodrine; α 2,5 dimethoxyphenyl β aminoethanol hydrochloride; serum; HPLC FLU; determination;
