reinliu
第7楼2013/02/05
专业用途的光伏面板是被RoHS 2.0豁免的:
原文Article 2, 4. This Directive does not apply to:(i) photovoltaic panels intended to be used in a system that is designed, assembled and installed by professionals for permanent use at a defined location to produce energy from solar light for public, commercial, industrial and residential applications;
但是,普通用途的太阳能发电装置(比如太阳能等,热水器之类),我觉得似乎不能适用该豁免
ian.cheng
第8楼2013/02/05
不错,这种理解也有道理。
