qq250083771
第3楼2012/11/07
152.2 高效液相色谱法测定乳块消合剂中丹参素的含量
【作者】 赖娟; 杨明; 莫强;
【Author】 LAI Juan~1,YANG Ming~1,MO Qiang~2(1.Chengdu University of TCM,Chengdu 611731,China;2.Jiangxi University of TCM,Nanchang 330006,China)
【机构】 成都中医药大学; 江西中医学院 四川成都611731; 四川成都611731; 江西南昌330006;
【摘要】 目的建立高效液相色谱法测定乳块消合剂中丹参素的含量。方法采用离心-微孔滤膜过滤的方法制备供试品溶液,色谱柱为D iamonsil-ODS C18柱(4.6 mm×250 mm,10μm);流动相为乙腈-甲醇-水-冰醋酸(0.5∶8∶92∶1),检测波长为280 nm,进行测定。结果方法的平均加样回收率为99.87%,RSD为1.73%;丹参素在0.106 7~1.067μg范围内线性良好(r=0.999 8)。结论该方法可靠,结果准确,可作为乳块消合剂的含量测定方法。 更多还原
【Abstract】 Objective To establish a method for determining the content of Danshensu in Rukuaixiao Mixture by HPLC.Methods The determination was carried out with Diamonsil-ODS C18 column;the mobile phase consisted of cetonitrile-methanol-water-glacial acetic acid(0.5∶8∶92∶1),and the detection wavelength was 280 nm.Results The average recovery of standard addition was 99.87%,RSD=1.73%;there was a good linear relationship between the absorption area value and the concentration in the range of 0.106... 更多还原
【关键词】 乳块消合剂; 高效液相色谱法; 丹参素;
【Key words】 Rukuaixiao mixture; HPLC; Danshensu;
qq250083771
第4楼2012/11/07
152.3 高效液相色谱法测定复方风湿丸中士的宁和马钱子碱的含量
【作者】 田华; 李元宏; 朱建成;
【Author】 TIAN Hua, LI Yuan-hong, ZHU Jian-cheng(Department of Pharmacy,Taihe Affiliated Hospital,Yunyang Medical College,Shiyan 442000)
【机构】 郧阳医学院附属太和医院; 郧阳医学院附属太和医院 湖北十堰442000; 湖北十堰442000; 湖北十堰442000;
【摘要】 目的:建立复方风湿丸中士的宁和马钱子碱含量测定的高效液相色谱法。方法:色谱柱DiamonsilC18(4.6mm×200mm,5μm);流动相为:甲醇-乙腈-水-冰-醋酸(45∶30∶25∶0.5);检测波长254nm;流速1.0ml/min。用硅胶固相萃取的样品预处理方法提取复方风湿丸中的士的宁和马钱子碱。结果:士的宁浓度在10~100μg/ml,马钱子碱浓度在6~60μg/ml范围内线性关系良好。士的宁r=0.9995,平均回收率99.55%,RSD为1.01%;马钱子碱r=0.9997,平均回收率99.73%,RSD为1.05%。结论:该方法检测结果准确,重现性好,能有效地控制复方风湿丸的质量。 更多还原
【Abstract】 Objective:To establish the HPLC method for detemination of strychnine and brucine in compound Fengshi Pills.Methods:HPLC was performed on Diamonsil C18(4.6 mm×200 mm,5 μm)with methanol-acetonitrile-HAC(45∶30∶25∶0.5)as mobile phase.Detecting wavelength was 254 nm and flow rate was 1.0 ml/min.Strychnine and Brucine in compound Fengshi Pills were extracted by silica gel solid-phase extraction method.Results:Linear ranges of Strychnine and Brucine were 10~100 μg/ml and 6 μg/ml~60 μg/ml re... 更多还原
【关键词】 高效液相色谱法; 复方风湿丸; 士的宁; 马钱子碱; 含量;
【Key words】 Compound Fengshi Pills; Strychnine; Brucine; Content;
qq250083771
第5楼2012/11/07
152.4 前体物及诱导剂对肉苁蓉松果菊苷含量的影响
【作者】 钟俐; 吴楠贞;
【Author】 ZHONG Li,WU Nan-zhen(College of Life Science and Technology,Xinjiang University,Urumqi 830046,China)
【机构】 新疆大学生命科学与技术学院;
【摘要】 目的:通过在寄主梭梭根部添加松果菊苷前体物质及其合成诱导剂,研究它们对肉苁蓉中松果菊苷积累的影响。方法:以高效液相色谱法测定不同处理的样品中松果菊苷的含量,采用DiamoNsil Dilcma C18(5μm,250×4.6mm)色谱柱;流动相:A相为1.5%醋酸溶液,B相为甲醇;流速0.5mL/min,检测波长335nm,室温。结果:松果菊苷在0.86~4.3μg的范围内线性关系良好,r=0.9996,平均地加样回收率为98.93%,RSD=4.36%。对寄主梭梭以不同种类和浓度的前体物质及诱导剂处理,均可促进肉苁蓉中松果菊苷的积累。结论:酪氨酸加诱导剂处理对松果菊苷积累的效果更为显著。 更多还原
【Abstract】 Objective:The effect of ehinacoside content of Cistanche deserticola was studied by adding precursors and revulsant to hosts.Set up the method on determination of the content of echinacoside in herbs of Cistanche deserticola by HPLC.Method:Chromatographic conditions were available as follows DiamoNsil Dilcma C18(4.6mm×250mm,5μm),l.5% acetate solution as mobile phase A,methanol as mobile phase B,flowrate was 0.5mL/min,and detecting wavelength was 335 nm,room temperature.Result:The linear correlat... 更多还原
【关键词】 肉苁蓉; 前体物质; 诱导剂; 松果菊苷; 高效液相色谱法;
【Key words】 Cistanche deserticola; precursors; revulsant; echinacoside; HPLC;
【基金】 新疆大学自然科学基金项目(编号:XY080110)资助
qq250083771
第6楼2012/11/07
152.5 黑曲霉固态发酵对淫羊藿苷含量的影响及检测
【作者】 谷春秀; 于燕; 王璐; 葛喜珍;
【Author】 Gu Chunxiu,Yu Yan,Wang Lu,Ge Xizhen(Biochemical Engineering College of Beijing Union University,Beijing,100023)
【机构】 北京联合大学生物化学工程学院;
【摘要】 目的:采用黑曲霉(Aspergillus niger)孢子悬液发酵淫羊藿,观察其对淫羊藿苷的影响,建立淫羊藿苷的检测方法。方法:淫羊藿在30℃、孢子浓度1.8×104/mL条件下固态预发酵7d。用水回流法、乙醇回流法、超声水提法、超声醇提法从淫羊藿中提取淫羊藿苷,HPLC法测定其含量。结论:发酵淫羊藿的色谱条件为:DiamonsilC18(250×4.6mm,5μm);流动相:甲醇-水-冰醋酸(60:40:0.25);检测波长:270nm;柱温:41℃;流速:1.0min/mL。发酵前后超声醇提法均优于其它方法,淫羊藿苷含量最高(5.06%、2.38%),水回流法(0.87、0.87%)、乙醇回流法(4.44、2.13%)、超声水提法(1.11、1.34%)发酵后淫羊藿苷含量发生变化,本研究为淫羊藿储藏期质量评价奠定基础。 更多还原
【Abstract】 Objective Herba Epimedii was fermented with spore suspension of Aspergillus niger and the method for detecting icariin during fermentation was established.Methods The solid-state fermentation condition was 30℃ for 7 days with spore density of 1.8×104/mL.The water reflux,ethanol reflux and ultrasonic water,ultrasonic ethanol extraction were applied for the extraction of icariin from Herba Epimedii.High performance liquid chromatography(HPLC) was employed to determine the icariin.Conclusion The su... 更多还原
【关键词】 淫羊藿; 固体发酵; 黑曲霉; 高效液相色谱;
【Key words】 Herba Epimedii; solid-state fermentation; Aspergillus niger; HPLC;
【基金】 北京市教育委员会科技发展计划资助项目(KM200911417011)
qq250083771
第7楼2012/11/07
152.6 HPLC法测定注射用法莫替丁的有关物质
【作者】 赵家太; 冀宛丽;
【Author】 Jiatai Zhao1, Wanli Ji2(1,Shanxi Taihang Pharmaceutical Co.Ltd Changzhi 0460002,Shanxi Changzhi Institute for Drug Control Changzhi 046000)
【机构】 山西太行药业股份有限公司; 山西省长治市药品检验所;
【摘要】 目的:用高效液相色谱法测定注射用法莫替丁中有关物质的含量。方法:采用Diamonsil C 18色谱柱;以0.01mol.L-1庚烷磺酸钠溶液-乙腈-甲醇(25∶6∶1),用冰醋酸调节pH至3.9;流速:1.0ml/min,检测波长为267nm。结果:有关物质的浓度在106~317μg.ml-1范围内均与峰面积呈良好的线性关系,r为0.9712,法莫替丁与有关物质能有效分离,有关物质的最低检测限(S/N=3)为0.02 ng.ml-1。结论:此方法简便、快速、准确,可用于该药有关物质的检查。 更多还原
【Abstract】 Objective: An HPLC method for the determination of relative substances in famotidine for injection was established.Methods: Diamonsil C 18 column;the mobile phases consisted of 0.01 mol ? L-1 sodium heptanesulfonate solution- acetonitrile-methanol (25∶6∶1)(adjust pH to 3.9 with Acetic acid ); The flow rate was 1.0ml/min, detecting wavelength was267nm. Results: Thelinear range of relative substances was106~317μg?ml-1,γ=0.9712, famotidine And relative substances can be effectively separated,The lo... 更多还原
【关键词】 高效液相; 法莫替丁; 有关物质;
【Key words】 HPLC; famotidine; relative substances;
qq250083771
第8楼2012/11/07
152.7 高效液相色谱-质谱联用法测定大鼠血浆中多西他赛的含量
【作者】 高坤; 陈凤菊; 孙进; 何仲贵;
【Author】 GAO Kun,CHEN Feng-ju,SUN Jin,HE Zhong-gui (School of Pharmacy,Shenyang Pharmaceutical University,Shenyang 110016,China)
【机构】 沈阳药科大学药学院; 沈阳药科大学药学院 辽宁沈阳110016; 辽宁沈阳110016;
【摘要】 目的建立大鼠血浆中多西他赛含量的测定方法,为药物动力学研究提供方法学基础。方法采用高效液相色谱-质谱联用法(HPLC-MS)。采用Diamonsil C18色谱柱(4.6 mm×200 mm,5μm),乙腈-质量分数为0.2%的甲酸水溶液(体积比66∶34)为流动相,流速为1.0 mL.min-1,柱温为25℃,进样量为20μL。质谱选择电喷雾电离源(ESI),选择离子监测(SRM)检测多西他赛母离子[M+H]+m/z809,内标格列吡嗪子离子m/z321。结果本法的线性范围为25~4 000μg.L-1;最低定量限为12.5μg.L-1;低、中、高质量浓度质控供试品的日内RSD均在4.09%~6.96%内,日间RSD均在5.34%~14.29%内,准确度相对误差(ER)均在-0.29%~-3.42%内,提取回收率均在85%以上。结论本法操作简便,灵敏度高,分析速度快,适用于大鼠血浆中多西他赛的含量测定。 更多还原
【Abstract】 Objective To establish a high-performance liquid chromatography-electrospray mass spectrometry(HPLC-MS) method for the determination of docetaxel in rat plasma.Methods The HPLC-MS method was performed on Diamonsil C18 column(4.6 mm×200 mm,5 μm) at 25 ℃,taking acetonitrile-0.2% formic acid(V∶V=66∶4) as mobile phase with flow rate of 1.0 mL·min-1;the injection volume was 20 μL.Acquisition was performed with the selected ion reaction monitoring mode(SRM) after the ionization in the electrospray ion... 更多还原
【关键词】 多西他赛; 高效液相色谱-质谱联用法; 含量测定;
【Key words】 doctaxel; high-performance liquid chromatography-electrospray mass spectrometry; content determination;
【基金】 辽宁省科技计划项目(2007102071)
qq250083771
第9楼2012/11/07
152.8 HPLC法同时测定舒胆胶囊中芦荟大黄素和延胡索乙素的含量
作者: 陈丽姑[1] 王进[2] 王冬梅[1] 赵怀清[1]
Author: CHEN Li-gu[1] WANG Jin[2] WANG Dong-mei[1] ZHAO Huai-qing[1]
作者单位: 沈阳药科大学,药学院,辽宁,沈阳,110016
本溪市中心医院,药学部,辽宁,本溪,117000
期 刊: 沈阳药科大学学报 ISTIC PKU
Journal: JOURNAL OF SHENYANG PHARMACEUTICAL UNIVERSITY
年,卷(期): 2008, 25(6)
关键词: 舒胆胶囊 芦荟大黄素 延胡索乙素 高效液相色谱法
摘要: 目的 建立同时测定舒胆胶囊中芦荟大黄素和延胡索乙索含量的方法,为完善现有质量标准提供科学依据.方法 采用HPLC法.用Diamonsil C18柱(200mm×4.6mm,5μm)分离,以甲醇-pH6.8磷酸盐缓冲液(体积比70:30)进行等度洗脱,流速为1.0mL·min-1,柱温为40℃,检测波长为280nm.结果 芦荟大黄素质量浓度在0.1300~2.600mg·L-1内、延胡索乙素质量浓度在4.352~87.04mg·L-1内与峰面积呈良好的线性关系,相关系数分别为0.9997和0.9999;平均回收率分别为100.0%(RSD=0.81%)和100.1%(RSD=0.33%).结论 本方法简便、快捷,结果准确,重复性好,可应用于舒胆胶囊的质量控制.
qq250083771
第10楼2012/11/07
152.9 HPLC法同时测定舒胆胶囊中4种蒽醌类成分的含量
【作者】 王冬梅; 陈丽姑; 赵怀清;
【Author】 WANG Dong-mei,CHEN Li-gu,ZHAO Huai-qing (School of Pharmacy,Shenyang Pharmaceutical University,Shenyang 110016,China)
【摘要】 目的建立同时测定舒胆胶囊中大黄酸、大黄素、大黄酚、大黄素甲醚含量的方法,完善现有质量标准。方法采用HPLC法。用Diamonsil C18柱(200 mm×4.6 mm,5μm)分离,用甲醇-水-磷酸(体积比84∶16∶0.1)进行等度洗脱,流速为1.0 mL.min-1,柱温为35℃,检测波长为254 nm。结果大黄酸质量浓度在0.220 0~4.400 mg.L-1内、大黄素质量浓度在0.162 0~3.240 mg.L-1内、大黄酚质量浓度在0.520 8~10.42 mg.L-1内、大黄素甲醚质量浓度在0.109 2~2.184 mg.L-1内与峰面积呈良好的线性关系,相关系数分别为0.999 7、0.999 9、0.999 8、0.999 9;平均回收率分别为100.5%(RSD=0.84%)、100.4%(RSD=0.51%)、100.8%(RSD=0.29%)、99.8%(RSD=0.47%)。结论本方法简便、快捷,结果准确,重复性好,可作为舒胆胶囊的质量控制方法之一。 更多还原
【Abstract】 Objective To establish an HPLC method for simultaneous determination of rhein,emodin,chrysophanol and physcion in Shudan(traditional Chinese medicines)capsules.Methods The chromatographic method was applied on a Diamonsil C18 column(200 mm×4.6 mm,5 μm) with methanol-water-phosphoric acid(V∶V∶V=84∶16∶0.1) as the mobile phase.The flow rate was 1.0 mL· min1 and column temperature was 35 ℃.The detection wavelength was set at 254 nm.Results The calibration curve was linear within the range of 0.220 0... 更多还原
【关键词】 舒胆胶囊; 大黄酸; 大黄素; 大黄酚; 大黄素甲醚; 高效液相色谱法;
【Key words】 Shudan capsule; rhein; emodin; chrysophanol; physcion; HPLC;
