第2楼2003/08/05
[1] 陈新坤 著. 电感耦合等离子体光谱法原理和应用[M]. 天津:南开大学出版社,1987. 34~44.
[2] Uchida H,Kiyoshi Tanabe, Yukihiro Nojiri,et al. Spatial Distribution of Metastable Argon, Temperature and Electron Number Density in an Inductively Coupled Argon Plasma[J]. Spectrochimica Acta. 1981,36B:711.
[3] 杜崇明. ICP-AES中基体效应与激发温度之间关系的探索[J]. 地质实验室. 1991,7(3):143.
[4] Caughlin B L, Blades M W. Analyte Ionization in Inductively Coupled Plasma[J]. Spectrochimica Acta. 1985, 40B: 1539.
[5] Raaijmakers I J M M, Mboumans P W, Der Sude, et al. A Theoretical and Experimental Investigation of Non-LTE Phenomena in an Inductively Coupled Argon Plasma——Ⅰ. Characterization of the Discharge[J]. Spectrochimica Acta. 1983,38B:697.
[6] Huang Mao, Grary Hieftji. A New Procedure for Determination of Electron Temperature and Electron Concentrations by Thomson Scattering from Analytical Plasmas[J]. Spectrochimica Acta. 1989,44B:291.
[7] Huang Mao, Grary Hieftji. Simultaneous Measurement of Spatially Resolved Electron Temperatures, Electron Number Densities and Gas Temperatures by Laser Light Scattering from the ICP[J]. Spectrochimica Acta. 1989, 44B:739.
[8] 金泽祥,艾军,陈琳. 有机溶剂与水溶液引入电感耦合等离子体电子密度及电子温度轴向分布的比较[J]. 分析化学. 1990,18(4):339.
[9] Mermet J M. Ionic to Atomic Line Intensity Ratio and Residence Time in Inductively Coupled Plasma-Atomic Emission Spectrometry[J]. Spectrochimica Acta. 1989, 44B: 1116.
[10] Blades M W. Some Considerations Regarding Temperature, Electron Density and Ionization in the Argon Inductively Coupled Plasma[J]. Spectrochimica Acta. 1982, 37B:869.
[11] Walker Z, Blades M W. Measurement of Excited State Level Population for Atomic and Ionic Iron in the Inductively Coupled Plasma[J]. Spectrochimica Acta. 1986,41B:761.
[12] Van der Mullen J A M, Laaijmakurs I J M, Van Lammeren A C A P, et al. On the Charge Transfer in an Inductively Coupled Argon Plasma[J]. Spectrochimica Acta. 1987,42B:1039.
[13] Blades M W, Caughlin B L, Walker Z H, et al. Excitation, Ionization and Spectral Line Emission in the Inductively Coupled Plasma[J]. Analyt Spectrosc. 1987,10B:57.
[14] 艾军,金泽祥,汤志勇. Ar-ICP非平衡参数和电离度测量及偏离局部热平衡的估计[J]. 武汉化工学院学报. 1994,16(2):16.
[15] 孙大海,张展霞,莫国宁,等. ICP-AES中基体及操作条件对元素电离度的影响[J]. 高等学校化学学报. 1991, 12(8): 1022.
[16] 郑建国,张展霞. 用Monte Carlo模拟方法研究ICP-AES中的电离和激发过程 Ⅰ. 基本原理[J]. 光谱学与光谱分析. 1996,16(1):73.
[17] 陈新坤 主编. 原子发射光谱分析原理[M]. 天津:天津科学技术出版社, 1991. 227~231.
[18] Karen Hanlon O, Les Ebdon, Michael Foulkes. Effect of Easily Ionisable Elements on the Mass Transport Efficiency of Solution and Slurries Used in Plasma Emission Spectrometry[J]. J Anal Atom Spectrometry. 1997, 12B:329.
[19] Dubuisson C, Emmaanuelle Poussel, Jeanmichel Mermet. Comparison of Axially and Radically Viewed Inductively Coupled Plasma Atomic Emission Spectrometry in Terms of Signal-to-background Ratio and Matrix Effects[J]. J Anal Atom Spectrometry. 1997, 12B: 281.
[20] 徐方平,陈新坤. 电感耦合等离子体光谱法中非光谱干扰效应的观测和统计检验[J]. 分析化学. 1990, 18(12): 1131.
[21] 杨金夫,曾宪津. 电感耦合等离子体光谱法分析中不同电离电位元素基体效应的比较研究[J]. 分析化学. 1990, 18(10):902.
[22] 罗建波,张展霞,钱浩雯. ICP-AES中三种进样方式对基体干扰的研究[J]. 分析测试通报. 1989,8(4):25.
[23] 张卓勇,刘思东,吉林白音,等. 电感耦合等离子体原子发射光谱分析信息系统的开发 Ⅰ. 系统分析[J]. 分析化学. 1998,26(3):317.
[24] 应海,杨凡原,王小如,等. ICP-AES初级专家系统中的谱线模拟[J]. 光谱学与光谱分析. 1996,16(1):67.
[25] Boumans P W J M. Corrections for Spectral Interference in Optical Emission Spectrometry with Special Reference to the RF Inductively Coupled Plasma[J]. Spectrochim Acta. 1976,31B:147.
[26] 张赣南,赵玉珍. ICP-AES中光谱干扰校正的计算方法[J]. 分析化学. 1986,14(9):703.
[27] Hassan S M, Nich T Loux. Elimination of Spectral Interference in Inductively Coupled Plasma Atomic Emission Spectroscopy Using Orthogonal Polynomials[J]. Spectrochim Acta. 1990,45B:719.
[28] 檀金宗,陈新坤,马锦秋. ICP-AES中元素间干扰的逐步逼近校正法[J]. 高等学校化学学报. 1988,9(10):993.
[29] 金泽祥,陈柏林,江惠坚,等. 相互干扰系数法校正ICP-AES多元素同时分析的光谱干扰[J]. 光谱学与光谱分析. 1998,18(3):329.
[30] Saxbery B E H, Kowalski B R. Correction of Interferences in Inductively Coupled Plasma Atomic Emission Spectrometry by Generalized Standard Addition Method[J]. Anal Chem. 1979,51:1031.
[31] 梁红健,张展霞,钱浩雯,等. 应用正交设计-广义标准加入法扣除电感耦合等离子体发射光谱分析中的干扰[J]. 光谱学与光谱分析. 1986,6(2):35.
[32] Yang Jin-fu, Piao Zhe-xiu, Zeng Xian-jin. Improvement of Selectivity with Numeral Derivati
