guangcai
第1楼2006/06/27
我使用过unscramber6.01
其帮助中有一个方法是直接拖动,即
An alternative import method is to use Drag’n Drop. The Editor supports OLE, so you can mark data in another Windows program and simply drag it into The Unscrambler’s Workspace or into an existing Editor document. If you drop the data table onto the Workspace, an Editor will be opened automatically.
意思就是你把Excel文件和unscrambler都打开,需建立新的unscrambler空白文件,选中excel中的内容,ctrl+直接拖动即可,我曾经用过,可以的,
如有问题,请发email我:guangcai_zhang@hotmail.com
