原子荧光光谱法同时测定莲子心中微量砷和汞
微波消解仪参数 | |||
阶段 | 压力(Mpa) | 时间(s) | 功率 |
1 | 0.5 | 60 | 100% |
2 | 0.8 | 60 | 100% |
3 | 1.2 | 120 | 100% |
4 | 1.8 | 240 | 100% |
5 | END | END | END |
表2 测砷汞的最佳分析条件 | |||
项目 | 测定条件 | 项目 | 测定条件 |
灯电流 | As-50mA | 负高压 | 270V |
Hg-20mA | 硫脲溶液 | 100g/L | |
硼氢化钾溶液 | 20g/L | 载气流量 | 400m L·min-1 |
原子化器高度 | 8.0mm | 屏蔽气流量 | 900m L·min-1 |
A道:Hg | |||||
标准系列 | 参与拟合 | 标准浓度 | 荧光强度 | 反算浓度 | 误差 |
STD.1 | Yes | 0.4 | 679.679 | 0.402 | 0.002 |
STD.2 | Yes | 0.8 | 1301.076 | 0.799 | -0.001 |
STD.3 | Yes | 1.2 | 1919.014 | 1.195 | -0.005 |
STD.4 | Yes | 1.6 | 2559.221 | 1.604 | 0.004 |
STD.5 | Yes | 2 | 3177.661 | 2 | 0 |
曲线参数 | A=1563.527 | B=51.097 | C=0.000 | D=0.000 | R=1.0000 |
B道:As | |||||
STD.1 | Yes | 2 | 247.54 | 2.002 | 0.002 |
STD.2 | Yes | 4 | 484.51 | 3.986 | -0.014 |
STD.3 | Yes | 6 | 726.938 | 6.016 | 0.016 |
STD.4 | Yes | 8 | 963.68 | 7.999 | -0.001 |
STD.5 | Yes | 10 | 1202.215 | 9.996 | -0.004 |
曲线参数 | A=119.426 | B=8.421 | C=0.000 | D=0.000 | R=1.0000 |
检出限数据 | |||||||||||
序号 | 标识 | A道 | 荧光强度 | 浓度 | 单位 | 检出限 | B道 | 荧光强度 | 浓度 | 单位 | 检出限 |
1 | blank1 | Hg | 8.979 | 0 | As | 14.395 | 0 | ||||
2 | blank2 | Hg | 6.809 | 0 | As | 15.015 | 0 | ||||
3 | blank3 | Hg | 9.262 | 0 | As | 15.198 | 0 | ||||
4 | blank4 | Hg | 12.293 | 0 | As | 15.748 | 0 | ||||
5 | blank5 | Hg | 10.189 | 0 | As | 15.73 | 0 | ||||
6 | blank6 | Hg | 10.89 | 0 | As | 16.051 | 0 | ||||
7 | blank7 | Hg | 12.52 | 0 | As | 16.693 | 0 | ||||
8 | blank8 | Hg | 12.836 | 0 | As | 17.001 | 0 | ||||
9 | blank9 | Hg | 16.862 | 0 | As | 17.829 | 0 | ||||
10 | blank10 | Hg | 16.148 | 0 | As | 18.125 | 0 | ||||
11 | blank11 | Hg | 19.271 | 0 | As | 18.857 | 0 | ||||
12 | STD.1 | Hg | 679.679 | 0.4 | μg/L | As | 247.54 | 2 | μg/L | ||
13 | STD.2 | Hg | 1301.076 | 0.8 | μg/L | As | 484.51 | 4 | μg/L | ||
14 | STD.3 | Hg | 1919.014 | 1.2 | μg/L | As | 726.938 | 6 | μg/L | ||
15 | STD.4 | Hg | 2559.221 | 1.6 | μg/L | As | 963.68 | 8 | μg/L | ||
16 | STD.5 | Hg | 3177.661 | 2 | μg/L | 0.0072 | As | 1202.215 | 10 | μg/L | 0.0354 |
精密度数据 | |||||||||||
序号 | 标识 | A道 | 荧光强度 | 浓度 | 单位 | 精密度 | B道 | 荧光强度 | 浓度 | 单位 | 精密度 |
1 | RSD.1 | Hg | 1944.483 | 1.2 | μg/L | As | 847.11 | 6 | μg/L | ||
2 | RSD.2 | Hg | 1988.632 | 1.2 | μg/L | As | 857.05 | 6 | μg/L | ||
3 | RSD.3 | Hg | 2021.467 | 1.2 | μg/L | As | 848.28 | 6 | μg/L | ||
4 | RSD.4 | Hg | 2037.037 | 1.2 | μg/L | As | 872 | 6 | μg/L | ||
5 | RSD.5 | Hg | 2101.45 | 1.2 | μg/L | As | 859.31 | 6 | μg/L | ||
6 | RSD.6 | Hg | 2087.335 | 1.2 | μg/L | As | 862.17 | 6 | μg/L | ||
7 | RSD.7 | Hg | 2127.797 | 1.2 | μg/L | As | 859.66 | 6 | μg/L | ||
8 | RSD.8 | Hg | 2104.765 | 1.2 | μg/L | As | 863.34 | 6 | μg/L | ||
9 | RSD.9 | Hg | 2138.742 | 1.2 | μg/L | As | 858.28 | 6 | μg/L | ||
10 | RSD.10 | Hg | 2156.455 | 1.2 | μg/L | As | 848.21 | 6 | μg/L | ||
11 | RSD.11 | Hg | 2170.675 | 1.2 | μg/L | 3.5 | As | 853.98 | 6 | μg/L | 0.9 |
称样量 | Hg浓度 | Hg含量 | 平均值 | RSD | As浓度 | As含量 | 平均值 | RSD |
0.5038 | 0.0121 | 0.0006 | 0.0006 | 0.02% | 0.4906 | 0.024345 | 0.0254 | 4.22% |
0.5040 | 0.0121 | 0.0006 | 0.534 | 0.026488 |
