我在故我思
第3楼2006/08/13
8131Aniline and Selected Derivatives by Gas Chromatography
8141aOrganophosphorus Compounds by Gas Chromatography Capillary Column Technique
8151aChlorinated Herbicides by [url=https://insevent.instrument.com.cn/t/Mp]gc Using Methylation or Pentafluorobenzylation Derivatization[/url]
8260bVolatile Organic Compounds by Gas Chromatography-Mass Spectrometry ([url=https://insevent.instrument.com.cn/t/Mp]gcMS)[/url]
我在故我思
第4楼2006/08/13
8270cSemivolatile Organic Compounds by Gas Chromatography-Mass Spectrometry (GCMS)
8275aSemivolatile Organic Compounds (PAHs and PCBs) in Soils-Sludges and Solid Wastes Using Thermal Extraction-Gas Chromatography-Mass Spectrometry (TE-GC-MS)
8310Polynuclear Aromatic Hydrocarbons
8315aDetermination of Carbonyl Compounds by High Performance Liquid Chromatography (HPLC)
8316Acrylamide, Acrylonitrile and Acrolein by High Performance Liquid Chromatography (HPLC)
我在故我思
第5楼2006/08/13
8318N-Methylcarbamates by High Performance Liquid Chromatography (HPLC)
8321aSolvent Extractable Nonvolatile Compounds by High Performance Liquid Chromatography-Thermospray-Mass Spectrometry (HPLC-TS-MS) or Ultraviolet (UV) Detection
8325Solvent Extractable Nonvolatile Compounds by High Performance Liquid Chromatography-Particle Beam-Mass Spectrometry (HPLC-PB-MS)
8330Nitroaromatics and Nitramines by High Performance Liquid Chromatography (HPLC)
我在故我思
第6楼2006/08/13
8331Tetrazene by Reverse Phase High Performance Liquid Chromatography (HPLC)
8332Nitroglycerine by High Performance Liquid Chromatography
8410Gas Chromatography-Fourier Transform Infrared (GC-FT-IR) Spectrometry for Semivolatile Organics Capillary Column
8430Analysis of Bis(2-chloroethyl) Ether and Hydrolysis Products by Direct Aqueous Injection GC-FT-IR
我在故我思
第7楼2006/08/13
8440Total Recoverable Petroleum Hydrocarbons by Infrared Spectrophotometry
8515Colorimetric Screening Method for Trinitrotoluene (TNT) in Soil
8520Continuous Measurement of Formaldehyde in Ambient Air
8011:1,2-Dibromoethane and 1,2-Dibromo-3-chloropropane by Microextraction and Gas Chromatography
8061aPhthalate Esters by Gas Chromatography with Electron Capture Detection (GC-ECD)
80111,2-Dibromoethane and 1,2-Dibromo-3-chloropropane by Microextraction and Gas Chromatography
我在故我思
第8楼2006/08/13
下面附件中是:
8290Polychlorinated Dibenzodioxins (PCDDs) and Polychlorinated Dibenzofurans (PCDFs) by High-Resolution Gas Chromatography-High-Resolution Mass Spectrometry (HRGC-HRMS)
8280aThe Analysis of Polychlorinated Dibenzo-p-Dioxins and Polychlorinated Dibenzofurans by High Resolution Gas Chromatography-Low Resolution Mass Spectrometry (HRGC-LRMS)附件
