我是风儿
第1楼2014/09/01
这些是错误提示:08/31/14 12:39:18 #1457 AMFC operating parameters are out of range. Replace AMFC.
08/31/14 12:39:19 #3004 Power Failure occurred.
08/31/14 12:39:33 #1152 Error: Backing solenoid valve(SVBK) did not open.
08/31/14 12:50:10 #1206 Error: Turbo is not slowing after purge cycle.
09/01/14 00:12:56 #1437 Error: 15V power supply malfunction.
09/01/14 00:20:38 #1437 Error: 15V power supply malfunction.
09/01/14 00:22:26 #1437 Error: 15V power supply malfunction.
09/01/14 00:24:39 #1437 Error: 15V power supply malfunction.
09/01/14 01:17:40 #1437 Error: 15V power supply malfunction.
09/01/14 01:49:28 #1437 Error: 15V power supply malfunction.
09/01/14 08:21:29 #1003 Execution Error: Can not execute during Plasma on
09/01/14 08:22:10 #1450 Error: Spray chamber temperature(H) is too low.
09/01/14 08:22:10 #1442 Error: Spray chamber temperature (L) is too low.
09/01/14 08:22:44 #1003 Execution Error: Can not execute during Plasma on
-1428,"({SEQ} ): 2014.09.01 08:22:55 CELL Temp. Sensor Error"
09/01/14 08:23:17 #1152 Error: Backing solenoid valve(SVBK) did not open.
-1428,"({SEQ} ): 2014.09.01 08:24:59 CELL Temp. Sensor Error"
09/01/14 08:25:21 #1152 Error: Backing solenoid valve(SVBK) did not open.
-1428,"({SEQ} ): 2014.09.01 08:26:23 CELL Temp. Sensor Error"
09/01/14 08:26:45 #1152 Error: Backing solenoid valve(SVBK) did not open.
