求一篇文献 Kinoshita K and Bett J A S. New York:Wiley,1988
电化学综合讨论
  • 诸位高手请帮忙!!!
    急需一篇文献 Kinoshita K and Bett J A S. New York:Wiley,1988
  • leotron
    第1楼2006/09/06
    这个比较难,没有给出期刊,卷,期号,也比较老的文献了。
  • 快乐的小马
    第3楼2006/09/07
    没见过你这样查文献的,什么都不说明白,至少说下哪方面的啊,要不然别人怎么可能帮到你呢?
    是下面这个文献吗?我只找到这个作者,年号能对上,期刊简写为JAS的太多了。
    O2 and N2 gas permselectivity of alternating copoly(vinylidene cyanide-vinyl acetate)
    Journal of Applied Polymer Science
    Volume 35, Issue 5, Date: April 1988, Pages: 1333-1340
    Hisao Hachisuka, Hitoshi Kito, Yoshiharu Tsujita, Akira Takizawa, Takatoshi Kinoshita
  • 快乐的小马
    第4楼2006/09/07
    Article
    Hisao Hachisuka, Hitoshi Kito, Yoshiharu Tsujita *, Akira Takizawa, Takatoshi Kinoshita
    Department of Materials Science and Engineering, Polymeric Materials Course, Nagoya Institute of Technology, Gokiso-cho, Showa-ku, Nagoya 466, Japan
    *Correspondence to Yoshiharu Tsujita, Department of Materials Science and Engineering, Polymeric Materials Course, Nagoya Institute of Technology, Gokiso-cho, Showa-ku, Nagoya 466, Japan
    Abstract
    The sorption and permeation of oxygen and nitrogen in and through alternating copoly(vinylidene cyanide-vinyl acetate) [copoly(VDCN-VAc)] (Tg = 176癈) membranes annealed for different periods just below Tg, 160癈, were investigated over the pressure range from 100 to 1000 cmHg. The dual-mode sorption and mobility models were used to analyze the results. A sub-Tg annealing of copoly(VDCN-VAc) caused a slight decrease in the amount of sorption in the membranes. This decrease in the amount of oxygen and nitrogen sorption can be attributed to a decrease in the Langmuir sorption capacity term, CH, with increasing sub-Tg annealing period. The densification of copoly(VDCN-VAc) membranes caused simultaneously by the annealing remarkably reduced diffusion coefficients for both gases. The reduction in diffusion coefficients of Langmuir mode, DH, for both gases was found to be larger than that of Henry's law mode, DD. Furthermore, permselectivity of oxygen to nitrogen, the ratio of permeability coefficient of oxygen to nitrogen ([bar P ]O2/[bar P ]N2), reached to 11.8 for the copoly(VDCN-VAc) annealed for 30 h. Evidently the reduction of DH and DD for nitrogen with increasing annealing period was much larger than that for oxygen.
    Received: 1 June 1987; Accepted: 23 July 1987
    只能帮你到这儿了
  • ji
    第5楼2006/09/07
    谢谢!!不是这篇,我在看书时看到有关内容,想知道其具体原因,但是其后的参考文献中之列了这么多。
  • linkon
    第6楼2006/09/11
    参考文献不会是这样写的吧,看不懂,连页码都没有,也不像是书,很难找的
  • ji
    第7楼2006/09/12
    是啊,是在一本叫电化学电容器的书中的参考文献上的
    感谢诸位的关注
    谢谢大家的帮忙
