塑料产品可以做哪些物性测试,全解!可能有你想要的。
  • sgsdebbyye
    2014/10/22
物性测试综合讨论
  • 塑料产品可以做哪些物理测试呢
    Shore Hardness Type A /D ASTM D2240-05(2010)
    ISO 868-2003
    邵氏A /D型硬度 GB/T 2411-2008
    ball indentation hardness ISO 2039-1:2001
    球压痕硬度 GB/T 3398.1-2008
    Tensile Strength/ Elongation at break /Tensile Modulus ASTM D638-10
    拉伸强度、断裂伸长率、拉伸模量 ISO 527-2:1993/Cor.1:1994
    GB/T 1040.2:2006
    Poisson ratio ASTM D638-10
    泊松比
    Flexural Strength /Flexural modulus ASTM D790-10
    ISO 178-2010
    弯曲强度、弯曲模量 GB/T 9341-2008
    IZOD Impact Strength ASTM D256-10(
    有缺口)
    ASTM D4812-06(
    无缺口)
    悬臂梁冲击强度 ISO 180:2000/Amd 1:2006
    GB/T 1843-2008
    CHARPY Impact Strength ASTM D6110-10
    简支梁冲击强度 ISO 179-1-2010
    GB/T 1043.1-2008
    Compressive Strength /Compressive Modulus ASTM D695-10
    ISO 604-2002
    压缩强度、压缩模量 GB/T 1041-2008
    Falling Weight Impact Strength ASTM D5420-10(Gardner Impact)
    落锤冲击强度 ASTM D4226-10(PVC建材)
    Taber Abrasion Resistance ASTM D1044-08(
    透明塑料)
    ISO 9352-1995
    磨耗性能(Taber) GB/T 5478-2008
    Shear Strength by Punch ASTM D732-10
    穿孔剪切强度
    Density ASTM D792-08(Immersion)
    密度 ISO 1183-1:2004 (Immersion)
    GB/T 1033.1-2008(
    浸泡法)
    Melt index(MI) ISO 1133:2005 cor.1-2006
    熔融指数 GB/T 3682-2000
    ASTM D1238-10
    Flow rate ratio ISO 1133:2005 cor.1-2006 C
    流动速率比 GB/T 3682-2000 C
    ASTM D1238-10 D
    Heat deflection temperature(HDT) ASTM D648-07
    ISO 75-2:2004
    热变形温度 GB/T 1634.2-2004
    Vicat softening temperature(VST) ASTM D1525-09
    ISO 306:2004
    维卡软化点 GB/T 1633-2000
    GB/T 8802-2001
    ISO 2507-1995
    Brittleness temperature ASTM D746-07
    低温脆化温度 ISO 974-2000
    GB/T 5470-2008
    Luminous transmittance ASTM D1003-07e1 A
    GB/T 2410-2008 A
    透光率 JIS K7361-1:1997
    ISO 13468-1:1996
    Haze ASTM D1003-07e1 A
    雾度 GB/T 2410-2008 A
    ISO 14782-1999/Cor 1.2005
    Specular gloss ASTM D2457-08
    镜面光泽度 ASTM D523-08
    GB/T 8807-88
    Water Absorption ASTM D570-98(2010)
    吸水率 ISO 62-2008
    GB/T 1034-2008
    Chemical Resitance ASTM D1693-08
    耐化学试剂 GB 1842-2008(聚乙烯)
    GB/T 2951.41-2008(
    电缆)
    Ball pressure test IEC 60695-10-2-2003
    球压测试 GB/T 5169.21-2006
    Shrinkage from mold dimension ASTM D955-08 Type A/ D2
    ISO 294-4:2001
    模具收缩率 GB/T 17037.4-2003
    GB/T 15585-1995
    Specimen preparation from injection molding
    参考相关材料性能参数
    注塑加工制样
