端慎木渐
第1楼2006/09/25
2. ASTM E 2213-2002 发布:2002.06.10 现行
电信和信息交换间的分支和交通工具系统的标准规范.5GHz波带上专注的短范围通讯中间入口控制和物理层规范
Standard Specifications and Information Exchange Between Roadside and Vehicle System-5GHz Band Dedicated Short Range Communications (DSRC) Medium Access Control (MAC) and Physical Layer (PHY) Specifications E(01-nov-2002)
3. ASTM E 2213-2003 发布:2003.07.10 现行
Standard Specification for Telecommunications and Information Exchange Between Roadside and Vehicle Systems 5 GHz Band Dedicated Short Range Communications (DSRC) Medium Access Control (MAC) and Physical Layer (PHY) Specifications
没有找到免费的地方,如果不行的话可以去购买,共26页.
