水质参数 | 量程mg/L | 实验室仪器 | 在线仪器 |
快速链接>> | 水质参数-金属离子 / 水质参数-有机物污染物 / 水质参数-消毒剂 / 水质参数-营养盐 / 水质参数-无机非金属污染物 / 水质参数-溶解气体 / 水质参数-电化学测定仪 / 水质参数-微生物指标 /水质参数- 其他 |
硬度 | 0.05-4.00 | DR5000/DR3900/DR2800/DR890 | APA6000硬度分析仪 |
| | 数字滴定器,电位滴定仪 | SP510硬度监测报警仪 |
总硬度 | 8-1000ug/L | DR5000/DR3900/DR2800 | none |
| 4-1000ug/L | DR5000/DR3900/DR2800 | none |
| | 数字滴定器,电位滴定仪 | none |
铝 | 0.008-0.8 | DR5000/DR3900/DR2800/DR890 | none |
0.002-0.25 | DR5000/DR3900/DR2800 | none |
0.02-0.5 | DR5000/DR3900/DR2800 | none |
| 0.02-0.8 | PCII | none |
钡 | 2-100 | DR5000/DR3900/DR2800 | none |
六价铬 | 0.01-0.7 | DR5000/DR3900/DR2800/DR890 | CRM-2C六价铬分析仪 |
总铬 | 0.01-0.7 | DR5000/DR3900/DR2800/DR890 | none |
六价铬/总铬 | 0.03-1.0 | DR5000/DR3900/DR2800 | none |
钴 | 0.01-2.0 | DR5000/DR3900/DR2800 | none |
镉 | 0.7-80 | DR5000/DR3900/DR2800 | none |
0.02-0.3 | DR5000/DR3900/DR2800 | none |
铜 | 0.04-5.0 | DR5000/DR3900/DR2800/DR890 | APA6000铜分析仪 |
none | 0.1-8.0 | DR5000/DR3900/DR2800 | none |
none | 2-210ug/L | DR5000/DR3900/DR2800/DR890 | none |
铁 | 0.009-1.400 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.2-6.0 | DR5000/DR3900/DR2800 | none |
亚铁 | 0.02-3.00 | DR5000/DR3900/DR2800/DR890 | none |
总铁 | 0.01-1.80 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.02-3.33 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.012-1.800 | DR5000/DR3900/DR2800/DR890 | none |
铅 | 5-150ug/L | DR5000/DR3900/DR2800 | none |
| 3-300ug/L | DR5000/DR3900/DR2800 | none |
| 0.1-2.0 | DR5000/DR3900/DR2800 | none |
锰 | 0.1-20 | DR5000/DR3900/DR2800/DR890 | none |
| 0.006-0.7 | DR5000/DR3900/DR2800/DR890 | none |
钼酸盐 | 0.2-40 | DR5000/DR3900/DR2800/DR891 | MO42钼酸盐分析仪 |
| 0.02-3.0 | DR5000/DR3900/DR2800/DR892 | none |
镍 | 0.02-1.8 | DR5000/DR3900/DR2800 | none |
| 0.006-1.000 | DR5000/DR3900/DR2800/DR890 | none |
| 0.1-6.0 | DR5000/DR3900/DR2800 | none |
钾 | 0.1-7.0 | DR5000/DR3900/DR2800 | none |
银 | 0.005-0.7 | DR5000/DR3900/DR2800 | none |
锌 | 50-2500CH3COOH | DR5000/DR3900/DR2800 | none |
钠 | | | 9245钠离子分析仪 |
甲草胺 | | DR5000/DR3900/DR2800 | |
| 0.1ppb,0.5ppb | PCII | |
阿特津莠去津(除草剂) | none | DR5000/DR3900/DR2800 | |
| 0.1,0.5,3.0ppb | PCII | |
苯并三唑(甲苯并三唑) | 1.0-16.0(1.0-20) | DR5000/DR3900/DR2800/DR890 | |
氰尿酸 | 5-50 | DR5000/DR3900/DR2800/DR890 | |
甲醛 | 3-500ug/L | DR5000/DR3900/DR2800 | |
联氨 | 4-600ug/L | DR5000/DR3900/DR2800/DR890 | 9186联氨分析仪 |
除氧剂 | 5-600ug/L碳酰肼 | DR5000/DR3900/DR2800/DR890 | |
| 3-450ug/LDEHA | DR5000/DR3900/DR2800/DR890 | |
| 9-1000ug/L对苯二酚 | DR5000/DR3900/DR2800/DR890 | |
| 13-1500ug/L异抗坏血酸盐 | DR5000/DR3900/DR2800/DR890 | |
| 15-1000ug/L甲乙酮肟 | DR5000/DR3900/DR2800/DR890 | |
土壤中的多氯联苯(PCB) | 1.0-5.0 | DR5000/DR3900/DR2800 | |
| 10-50 | DR5000/DR3900/DR2800 | |
挥发酚 | 0.002-0.2 | DR5000/DR3900/DR2800 | |
膦酸盐 | 紫外消解法(多个量程0.02-2.50或1.0-125.0) | DR5000/DR3900/DR2800/DR890 | |
阴离子表面活性剂 | 0.002-0.275LAS | DR5000/DR3900/DR2800/DR890 | |
单宁酸和木质素 | 0.1-9.0 | DR5000/DR3900/DR2800/DR890 | |
土壤中的总石油烃(TPH) | 免疫管法 | DR5000/DR3900/DR2800 | |
水中的总石油烃 | 免疫管法 | DR5000/DR3900/DR2800 | |
三卤甲烷 | 10-600ug/LCHCL3 | DR5000/DR3900/DR2800 | |
有机物,紫外吸收 | N/A | DR5000 | UVAS sc有机物分析仪 |
none | | | UVAS eco sc紫外吸收在线分析仪 |
总有机碳(TOC) | 100-700C | DR5000/DR3900/DR2800 | 1950 PlusTOC分析仪 |
| 20-700C | DR890 | Astro TOC UV TURBO总有机碳分析仪 |
| 0.3-20C | DR5000/DR3900/DR2800/DR890 | Astro TOC UV TOC分析仪 |
| 15-150C | DR5000/DR3900/DR2800/DR890 | Astro TOC UV TOC分析仪 |
| | | Astro TOCTM HT总有机碳分析仪 |
水中油 | | | FP360 sc水中油分析仪 |
化学需氧量(CODCr) | 3-150 COD | DR5000/DR3900/DR2800/DR890 | CODmax铬法COD分析仪 |
| 20-1500 COD | DR5000/DR3900/DR2800/DR890 | COD203A型CODMn分析仪 |
| 200-15000 COD | DR5000/DR3900/DR2800/DR890 | NPW-150总磷/总氮/COD分析仪 |
| 0.7-40 COD | DR5000/DR3900/DR2800 | |
| 1-60 COD | DR5000/DR3900/DR2800 | |
| 3-150 COD | DR5000/DR3900/DR2800 | |
| 20-1500 COD | DR5000/DR3900/DR2800 | |
| 250-15000 COD | DR5000/DR3900/DR2800 | |
| 25-1000 COD | DR5000/DR3900/DR2800 | |
| 15-150 COD | DR5000/DR3900/DR2800/DR890 | |
| 100-1000 COD | DR5000/DR3900/DR2800/DR890 | |
挥发性酸 | 27-1800 | DR5000/DR3900/DR2800/DR890 | |
氯化物 | 0.1-25.0 | DR5000/DR3900/DR2800 | |
二氧化氯 | 0.04-5.00 | DR5000/DR3900/DR2800/DR890 | 9187 sc二氧化氯分析仪 |
| 1-50(直读) | DR5000/DR3900/DR2800/DR890 | |
| 5-1000(直读) | DR5000/DR3900/DR2800 | |
| 0.01-1.00 | DR5000/DR3900/DR2800 | |
游离余氯 | 0.02-2.00 | DR5000/DR3900/DR2800/DR890 | |
| 0.04-4.5 | DR5000/DR3900/DR2800 | |
| 0.05-2.0 | DR5000/DR3900/DR2800 | |
| 0.1-10.0 | DR5000/DR3900/DR2800/DR890 | |
| 0.09-5.00 | DR5000/DR3900/DR2800/DR890 | |
总余氯 | 0.02-2.00 | DR5000/DR3900/DR2800/DR890 | CL17余(总)氯分析仪 |
| 2-500ug/L | DR5000/DR3900/DR2800 | |
余氯&总氯 | 0.05-2.00 | DR5000/DR3900/DR2800 | CL17余(总)氯分析仪 |
| | | 9184 sc余氯分析仪 |
一氯胺 | 0.1-10.0(Cl2) | DR5000/DR3900/DR2800 | APA6000氨/一氯胺分析仪 |
| 0.04-4.5(Cl2) | DR5000/DR3900/DR2800/DR890/PCII | |
臭氧 | 0.01-2.50 | DR5000/DR3900/DR2800/DR890 | 9185臭氧分析仪 |
| 0.01-0.75 | DR5000/DR3900/DR2800/DR890 | |
| 0.01-1.50 | DR5000/DR3900/DR2800/DR890 | |
氨氮 | 0.02-2.50 | DR5000/DR3900/DR2800/DR890 | AmtaxTM Compact氨氮分析仪 |
| 0.01-0.50 | DR5000/DR3900/DR2800/DR890 | AmtaxTM inter2氨氮分析仪 |
| 0.4-50 | DR5000/DR3900/DR2800/DR890 | AmtaxTM sc氨氮分析仪 |
| 2-47 | DR5000/DR3900/DR2800 | NH4D sc氨氮分析仪 |
| 0.015-2.00 | DR5000/DR3900/DR2800 | |
| 1.0-12.0 | DR5000/DR3900/DR2800 | |
游离氨 | 0.0-0.0.50 | DR5000/DR3900/DR2800/DR890 | |
总氮 | 5-40 | DR5000/DR3900/DR2800 | NPW-150总磷/总氮/COD分析仪 |
| 2-150(10-150) | DR5000/DR3900/DR2800/DR890 | |
| 0.5-25.0 | DR5000/DR3900/DR2800/DR890 | |
| 1.0-16.0 | DR5000/DR3900/DR2800 | |
| 20-100 | DR5000/DR3900/DR2800 | |
| 0.5-30 | IL500总氮自动分析仪 | |
| 30-150 | IL500总氮自动分析仪 | |
总凯氏氮 | 1-150 | DR5000/DR3900/DR2800 | |
总无机氮 | 0.2-25.0 | DR5000/DR3900/DR2800/DR890 | |
| 0-16(亚硝氮可忽略时) | DR5000/DR3900/DR2800 | |
硝酸盐 | 0.3-30 | DR5000/DR3900/DR2800/DR890 | Nitratax sc硝氮分析仪 |
| 0.1-10(0-5)UV直读法 | DR5000 | NO3D sc硝氮分析仪 |
| 0.1-10.0 | | |
| 0.01-0.50 | DR5000/DR3900/DR2800/DR890 | |
none | 0.2-30.0 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.23-13.5 | DR5000/DR3900/DR2800 | none |
none | 5-35 | DR5000/DR3900/DR2800 | none |
亚硝酸盐 | 0.002-0.3 | DR5000/DR3900/DR2800 | none |
none | 0.005-0.35 | DR890 | none |
none | 2-150 | DR890 | none |
none | 2-250 | DR5000/DR3900/DR2800 | none |
none | 0.003-0.5 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.015-0.6 | DR5000/DR3900/DR2800 | none |
none | 0.6-60 | DR5000/DR3900/DR2800 | none |
酸可水解磷 | 0.07-5.0 | none | none |
none | 0.06-3.5 | none | none |
活性磷 | 0.23-30.00 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.3-45.0 | DR5000/DR3900/DR2800/DR890 | none |
none | 1.0-100.0 | DR5000/DR3900/DR2800/DR890 | none |
none | 19-3000ug/L | DR5000/DR3900/DR2800 | none |
none | 0.06-5.00 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.02-2.50 | DR5000/DR3900/DR2800/DR890 | none |
none | 5.0-90.0 | DR5000/DR3900/DR2800 | none |
总磷 | 0.06-3.50 | DR5000/DR3900/DR2800/DR890 | Phosphax Sigma总磷/正磷酸盐分析仪 |
none | 1.0-100.0 | DR5000/DR3900/DR2800/DR890 | NPW-150总磷/总氮/COD分析仪 |
none | 0.01-3.8 | IL500总磷自动分析仪 | none |
活性磷&总磷 | 0.15-4.50 | DR5000/DR3900/DR2800 | none |
none | 1.5-15.0 | DR5000/DR3900/DR2800 | none |
none | 6-60 | DR5000/DR3900/DR2800 | none |
正磷酸盐 | none | none | Phosphax sc正磷酸盐分析仪 |
水质参数- 无机非金属污染物
砷 | 0-0.200 | DR5000/DR3900/DR2800 | none |
硼 | 0.2-14.0 | DR5000/DR3900/DR2800 | none |
汞 | 0.1-12ug/L | DR5000/DR3900/DR2800 | none |
硒 | 0.01-1.00 | DR5000/DR3900/DR2800 | none |
硅 | 1-75 | DR890 | 5000系列硅分析仪 |
3-200 | DR890 | 9210硅分析仪 |
1.0-100.0 | DR5000/DR3900/DR2800 | none |
0.01-1.60 | DR5000/DR3900/DR2800/DR890 | none |
3-1000ug/L | DR5000/DR3900/DR2800 | none |
溴 | 0.05-4.50 | DR5000/DR3900/DR2800/DR890 | none |
碘 | 0.07-7.00 | DR5000/DR3900/DR2800 | none |
氯离子 | none | 数字滴定器/电位滴定仪 | 8810氯离子分析仪 |
氰化物 | 0.002-0.24 | DR5000/DR3900/DR2800/DR890 | none |
总碱度 | 25-400 | DR5000/DR3900/DR2800 | APA6000碱度分析仪 |
硫酸盐 | 5-70 | DR890 | none |
none | 2-70 | DR5000/DR3900/DR2800 | none |
none | 40-150 | DR5000/DR3900/DR2800 | none |
none | 150-900 | DR5000/DR3900/DR2800 | none |
硫化物 | 0.01-0.7 | DR890 | none |
none | 5-800ug/L | DR5000/DR3900/DR2800 | none |
亚硫酸盐 | 0.1-5.0 | DR5000/DR3900/DR2800 | none |
季铵盐 | 0.2-5.0 | DR5000/DR3900/DR2800 | none |
氟化物 | 0.02-2.00 | DR5000/DR3900/DR2800/DR890 | CA610氟化物分析仪 |
none | none | none | FBM-160/FBM-100A氟离子浓度分析仪 |
溶解氧 | 10-1000ug/L | DR890 | HACH LDOTM荧光法无膜溶解氧分析仪 |
none | 6-800ug/L | DR5000/DR3900/DR2800 | Zuling S-14溶解氧分析仪 |
none | 0.3-15.0 | DR5000/DR3900/DR2800/DR890 | HACH GLI 极谱法溶解氧分析仪 |
none | 1.0-40.0 | DR5000/DR3900/DR2800 | 9182微量溶解氧分析仪 |
none | none | none | G1100荧光法微量溶解氧分析仪 |
氢气 | none | none | Orbisphere510微量溶解氢分析仪 |
水质参数- 电化学测定仪 |
pH、电导、ORP、TDS、盐度、溶解氧、ISE(钠离子、氟离子、氯离子、硝酸根离子、氨离子) | none | sensION+系列电化学测定仪,MP系列 | 8362sc高纯水用pH分析仪 |
none | none | none | GLI pH/ORP分析仪 |
none | none | none | GLI差分Ph/ORP分析仪 |
none | none | none | GLI 3/4英寸复合pH/ORP分析仪 |
none | none | none | 可以直接输出4-20mA的差分pH/ORP电极 |
pH、电导、ORP、溶氧 | none | H系列 | 数字化pH/ORP传感器 |
none | none | none | GLI电导率分析仪 |
none | none | none | GLI3400系列高性能电导率探头 |
none | none | none | 数字化3400系列高性能电导率传感器 |
none | none | none | GLI无电极式电导率分析仪(浓度计) |
none | none | none | GLI3700E系列无电极电导率探头 |
none | none | none | 数字化GLI3700E系列无电极电导率传感器 |
none | none | none | si792本安防爆型变送器 |
浊度 | 0-10000NTU | 2100AN | 1720低量程浊度仪 |
none | 0-1000 | 2100Q | FilterTrak660sc超低量程浊度仪 |
none | 0-4000 | 2100N | SolitaxTM sc浊度/悬浮物(污泥浓度)分析仪 |
none | 0-1000,0-99.9,0-9.99 | 1900C | Surface Scatter 7 sc高量程浊度仪 |
none | none | none | Accu4/T53低量程浊度分析仪 |
none | none | none | ULTRATURB plus sc浊度分析仪 |
none | none | none | TSS sc浊度、悬浮物和污泥浓度分析仪 |
none | none | none | COSMOS-25浊度、悬浮物污泥浓度分析仪 |
SS(固体悬浮物) | 5-750 | DR5000/DR3900/DR2800/DR890 | none |
none | 0.001-400g/L | TSS 便携式浊度、悬浮物和污泥界面监测仪 | none |
none | none | none | 2200 PCX粒度计数器 |
色度 | 3-200 | DR5000/DR3900/DR2800 | none |
none | 15-500 | DR5000/DR3900/DR2800/DR890 | none |
总大肠菌群 | 滤膜法 | MEL | none |
类大肠菌群 | 滤膜法 | MEL | none |
污泥层高度、厚度 | none | none | SONATAX sc污泥界面测量仪 |
明渠流量 | none | none | U53型超声波明渠流量计 |
pH、电导、ORP、TDS、盐度、溶解氧、温度、深度、浊度、叶绿素a、蓝绿藻、若丹明WT、铵/氨离子、硝酸根离子、氯离子、环境光、总溶解气体共十五种参数 | none | none | Hydrolab多参数水质检测仪 |
水质自动采样器和流量计 | none | none | American Sigama水质自动采样器和流量计 |
油膜检测 | none | none | ODL-20/SODL-20水上油膜检测仪 |
污染密度指数(SDI) | none | none | SDI自动分析仪 |
