symmacros
第10楼2015/07/01
Swagelok® Liquid Leak Detectors
Snoop® and Real Cool Snoop liquid leak detectors detect gas leaks in hard-to-reach areas.
•Sustained bubble action works even on very small leaks and vertical surfaces.
•Flexible snooper tube extends for hard-to-reach areas.
•Formula does not contain chlorine, aliphatic amines, or ammonium compounds.
•Formula dries clean, without staining.
