大陆
第6楼2008/04/01
怕有些新手不会使用,特意写了一个使用说明:
Procedures:
0)copy source data file (such as test.txt) into the directory where lies convert.exe
1)run convert.exe
2)input the filename test.txt, then strike Enter
3)the cursor is now on the data type selection field, just strike Enter again then select input data type.
4)the cursor now goes back to filename field, press F2 (the second function key) to confirm your input.
5)input your destination filename, such as test.gsa, then press Enter
6)At the moment the cursor is indication of the data type selection, press Enter and select your destination filetype, such as gsas, then strike Enter.
7)press F2 key again.
8)everything has been done, OVER.
以下是网站上关于软件的介绍
CONVERT is an imaginatively-named programme for converting between different X-ray powder diffraction file formats. OK, so it might be a bit crude in places and is an old DOS application, but it's got us out of a tight spot occasionally and it might do the same for you too.
The most recent version is dated 26/5/98 (Support for new filetypes), and the following file formats are supported:
CONVERT reads : writes :
Philips VAX - APD Philips VAX - APD
Philips PC - APD (RD format) Philips PC - APD (RD format)
RIET7 Rietveld RIET7 Rietveld
GSAS GSAS
ASCII 2-theta,I lists ASCII 2-theta,I lists
SCANPI SCANPI
Philips PC - APD (SD format) Sietronics CPI
Siemens DiffracPlus
FullProf
You abuse the author by sending mail to m.bowden@irl.cri.nz.
But wait... there's more!! (No, not a set of steak knives). You might also want to download VCTCONV.EXE, a similar programme for converting between Variable Count Time data files and GSAS ESD data files. The VCT file format comes from the SR5 Rietveld system developed by the CSIRO Division of Minerals.
Download link for VCTCONV.exe: http://www.ccp14.ac.uk/ccp/web-mirrors/convx/vctconv.zip
For further information read about the VCT system http://www.minerals.csiro.au/tour/vct.htm , or visit the FTP site for the SR5 programmes http://www.ccp14.ac.uk/ccp/ccp14/ftp-mirror/csirominerals-anon-ftp/pub/xtallography/sr5/.
