Insp_369c9de6
第3楼2022/01/19
?Test method 测试方法?CDPH/ EHLB/ Standard Method Version 1.2-California Specification 01350:CDPH/ EHLB/标准方法1.2 版--加州 01350章节要求?Standard Method For the Testing and Evaluation of Volatile Organic Chemical Emissions From Indoor Sources Using Environmental Chambers?使用环境仓测试和评估室内源释放挥发性有机化学物质的标准方法?ISO 16000-3:2011?Indoor air-Part 3: Determination of formaldehyde and other carbonyl compounds in indoor air and test chamber air-Active sampling method?室内空气 第3部分∶室内空气和测试仓空气中甲醛和其它羰基化合物含量的测定-主动抽样法?ISO 16000-6:2011?Indoor air-Part 6: Determination of volatile organic compounds in indoor and test chamber air by active sampling on Tenax TA sorbent, thermal desorption and gas chromatography using MS/FID?室内空气 第 6部分∶通过在 Tenax TA吸收剂上活性取样,热脱附和GC-MS/FID 测定室内和测试仓空气中挥发性有机化合物的含量?ISO 16000-9:2006?Indoor air-Part 9: Determination of the emission of volatile organic compounds from building products and furnishing-Emission test chamber method?室内空气 第 9部分∶建筑产品和家具释放挥发性有机化合物的测定-测试仓释放测试法?ASTM D5116-10?Standard Guide for Small-Scale Environmental Chamber Determinations of Organic Emissions From Indoor Materials/ Products?小型环境仓室内装修材料/产品有机物排放量测定的标准指导
更多的信息可以加我威信 4451664.
