zjn1123
第4楼2017/09/27
你的理解是对的
hjada
第7楼2017/11/01
DP (Declustering Potential): The DP parameter controls the voltage on
the orifice, which controls the ability to decluster ions between the
orifice and the QJet? Ion Guide. It is used to minimize the solvent
clusters that may remain on the sample ions after they enter the vacuum
chamber, and, if desired, to fragment ions before entering the QJet Ion
Guide. The higher the voltage, the higher the energy imparted to the ions.
If the DP parameter is too high, unwanted fragmentation may occur.
The Declustering Potential uses the Access ID DP. It is also displayed
by its Parameter ID OR.
这是他们的说明书上解释的!
