求助如下三篇英文文章,感谢大家的帮助! 1、The Selection of Materials and Fabricating Techniques for the Eddystone Boiler and Sulzer Control Valves 作者:EC Chapman, RE Lorentz
2、Material Selection, Fabrication, Main Steam Piping for Eddystone 1,1200-F and5000-psi 作者:R. H. Caughey, W. G. Benz 出版源:《Journal of Engineering for Power》, 1960 , 82 (4) 链接:http://gasturbinespower.asmedigitalcollection.asme.org/article.aspx?articleid=1415901
3、Metallurgical Considerations of Main SteamPiping for High-Temperature, High-Pressure Service 作者:H. S. Blumberg 出版源:ASME paper no. 56-A-157, reprinted in Transactionsof the ASME, August 1957, vol. 79, no. 6, pp. 1377-1397.
你好!不好意思,第3篇的标题是“Metallurgical Considerations of Main SteamPiping for High-Temperature, High-Pressure Service”。谢谢! 再ASME数据库里面检索,没有这个题目的文献,这个作者的文献也没有见到1957年的。
