【英语翻译求助】请专业英语进来帮忙!
  • 怪侠一点红
    2007/01/09
文献检索-互助
  • eMolecules - Searching the World's ChemistryTM
    Welcome to eMolecules ... the chemical search engine you've been waiting for. We have actively assembled the world's largest repository of publicly accessible chemistry information. Now, it's easier and faster than ever to find the chemical information necessary to do your work more efficiently and effectively.
    Draw chemical structures using drawing packages such as JME, ISIS/Draw, ChemDraw or ChemSketch.
    Instantly search over 5.6 million unique chemical structures from more than 140 leading chemical suppliers, including Acros, ASINEX, ChemBridge, ChemDiv, Comgenex, Enamine, Fluka, Key Organics, Life Chemicals, Maybridge, Otava, Sigma-Aldrich, Specs, and others.
    Search results include valuable reference links to properties and spectra from sources such as DrugBank, National Cancer Institute, NIST WebBook, PubChem, EPA and more.
    Use powerful list management and export tools to facilitate internal compound screening and analytics.
    Select compounds, create a list and automatically generate requests for quote from selected vendors.
    What else is cool about eMolecules search?
    eMolecules is designed and built by chemists; it's optimized for the special needs of chemistry professionals.
    We search the way you think, using molecular structures to visualize, understand and search for chemistry data.
    The eMolecules thesaurus has amassed a comprehensive chemistry name space — including common names, IUPAC names and trade names — with corresponding chemical structures.
    We will continue to add valuable information such as calculated properties, MSDS, assay data, spectra, NMR and more.
    eMolecules is bringing of the power of Web 2.0 to chemists around the world.
    The wait is over ... start using the world's most powerful online chemical informatics system today.
  • 怪侠一点红
    第1楼2007/01/09
    帮我转贴,链接!
  • happyjyl
    第2楼2007/01/09
    点击“维护”,进去后转移到专业英语翻译版就行啦!
  • happyjyl
    第3楼2007/01/09
    你是要翻译吗?
  • 怪侠一点红
    第4楼2007/01/09
    我知道那样可以做到,但是我想让我版也保留此贴。
    这是我们合作的开始与见证!
  • 何当奇
    第5楼2007/01/09
    是的。
    看看这个帖子
    http://www.instrument.com.cn/bbs/shtml/20070109/703136/
    happyjyl 发表:你是要翻译吗?
  • 怪侠一点红
    第6楼2007/01/09
    红狐你就将他转贴发吧!谢谢啊!
    redanqi 发表:是的。
    看看这个帖子
  • 何当奇
    第7楼2007/01/09
    想到个问题,转移过去了的话,专业英语这里不就没有这个帖子了吗??
    bing_xuhong 发表:帮我转贴,链接!
  • 何当奇
    第8楼2007/01/09
    好的,这个帖子在文献检索这里已经有了
  • 何当奇
    第9楼2007/01/09
    happyjyl动作很快阿,但是还要重新转回去呢,
  • 怪侠一点红
    第10楼2007/01/09
    好吧,看来也只有这样了!
