ASTM D1148 - 13(2018) Standard Test Method for Rubber Deterioration—Discoloration from Ultraviolet (UV) or UV/Visible Radiation and Heat Exposure of Light-Colored Surfaces
liuxilin12152018/12/14
[quote]原文由 [b]穿越时空(fscmj)[/b] 发表:
沉下去了,帮你顶上来.[/quote] ASTM D1148-13(R2018) Standard Test Method for Rubber Deterioration—Discoloration from Ultraviolet (UV) or UV/Visible Radiation and Heat Exposure of Light-Colored Surfaces
