全自动的乌氏粘度计
综合仪器采购
  • 我公司想买一台全自动的乌氏粘度计,用来测树脂的特性粘度,不知道哪个公司的好一些,最好是国外的,价格贵一些不要紧,主要是仪器要好,请问那位知道,不胜感激。
  • 第1楼2004/09/02
    动力粘度计测量装置不必要称为“XX粘度计”
    因为基本装置是一样的,换成不同的粘度管,就是不同的粘度测定仪。
    目前美国凯能(CANNON),德国劳达(LAUDA)(不一定要翻译成老大),有商品仪器销售。
    自动化程度不同,价格相差很大。
    当然国产品也可以使用。
  • 第2楼2004/09/02
    Cannon* CT-1000 Constant-Temperature Viscosity Bath
    • Temperature range of 20° to 150°C
    • Solid-state temperature control to within ±0.01°C
    Specifically for precise viscosity determinations with glass capillary viscometers. Also suitable for temperature control of other instruments that must be viewed while immersed in a constant-temperature bath. Maintains accurate temperature control of ±0.01°C within the range 20° to 100°C and ±0.03°C above 100°C—ideal for ASTM D 445 kinematic viscosity specifications. Top cover contains seven 2 in. diameter (51mm) holes for insertion of viscometer holders. Two additional holes are provided for thermometers. Two electric heating elements inside bath rapidly heat medium to any desired temperature within range. Cooling coil permits operation below or slightly above ambient temperature when connected to tap water or a cooling system. Selector switch on front panel facilitates rapid setting of ten popular temperatures (20°, 25°, 30°, 40°, 50°, 60°, 80°, 100°, 135°, and 150°C) for kinematic viscosity determinations. After temperature has been selected, bath equilibrates to within 0.2° of desired temperature. Fine-tune control then allows temperature adjustment to within ±0.01°C of temperature. By switching to "variable" setting, any temperature within operating range can be obtained. Solid-state control circuit provides proportional control of temperature with stainless-steel–encased thermistor sensing element. Motor-driven stirrer ensures uniform temperature throughout bath. Plus, entire electrical control system is readily accessible if adjustments or repairs are necessary —simply pull out convenient drawer. Clear, cylindrical glass bath chamber measures 11 13/16 in. diameter x 11 13/16 in. high (30 x 30cm) and is illuminated by two fluorescent lamps. Stainless-steel baffle in center of bath provides a plain reflective background for viewing instruments. The CT-1000 Bath has several built-in safety features including a second thermistor in the bath that senses any overtemperature condition and quickly shuts down power to the bath until overtemperature limit circuit is reset. Another feature cuts power to bath heaters if the control thermistor is disconnected. A liquid-level control prevents bath heaters from operating when liquids are below minimum safe operating level.
    Drawer Unit
    Sturdy two-drawer unit fits beneath CT-1000 constant-temperature bath. Provides elevated viewing and ample room for storage of viscometers and other accessories. Dimensions, 18L x 18W x 6 1/2 in.H (46 x 46 x 17cm). Weight, 24 lb. (11kg).
    粘度计支架
    K23376 KV1000 Digital Constant Temperature Kinematic Viscosity Bath
    Test Method
    Kinematic viscosity is of primary importance in the design and selection of a wide range of petroleum products. Calibrated capillary viscometers are used to measure flow under gravity or vacuum at precisely controlled temperatures.
    Features and Benefits
    • Accommodates six capillary viscometers
    • Variable temperature limit control
    • Conforms to ASTM D445 and related specifications
    KV1000 Kinematic Viscosity Baths
    Constant temperature bath for kinematic viscosity testing of petroleum products. Accommodates six round 2" (51mm) dia. viscometer holders. Bath temperature stabilizes within ±0.5°C (±1°F) of setting, and final adjustment to within ±0.01°C (±0.02°F) can be made. Test temperatures of up to 150°C (302°F) can be selected. Temperature limit control permits the operator to select an overtemperature cutoff point to protect against accidental overheating. Control unit includes immersion heater, circulating stirrer and temperature probe. Composition top plate rests on a 12x12" (30.5x30.5cm) or 12x18" (30.5x46cm) Pyrex™ jar. Order capillary viscometers, viscometer holders and thermometer separately.
    Specifications
    Conforms to the specifications of:
    ASTM D445, D6074, D6158; IP 71; ISO 3104; DIN 51550;
    FTM 791-305; NF T 60-100
    Capacity: Six (6) glass capillary viscometers
    Bath Medium: water or white technical oil
    Included Accessories
    Port Covers, stainless steel (6)
    Catalog
    Number    Model    Electrical Requirements    Bath
    Depth    Bath
    Capacity    Dimensions
    diaxh,in.(cm)    Net
    Weight
    K23376    KV1000    115V, 50/60Hz
    Single Phase, 10.2A    12"
    (31cm)    5.8 gal
    (22 L)    13.5x20
    (34.6x50.8)    25 lbs
    (11.3kg)
    K23371    KV1000    115V, 50/60Hz
    Single Phase, 10.2A    18"
    (46cm)    8.9 gal
    (34 L)    19.5x23
    (49.5x58.4)    38 lbs
    (17.2kg)
    K23377    KV1000    220-240V, 50Hz
    Single Phase, 5.3A    12"
    (31cm)    5.8 gal
    (22 L)    13.5x20
    (34.6x50.8)    25 lbs
    (11.3kg)
    K23378    KV1000    220-240V, 50Hz
    Single Phase, 5.3A    18"
    (46cm)    8.9 gal
    (34 L)    19.5x23
    (49.5x58.4)    38 lbs
    (17.2kg)
    K23373    KV1000    220-240V, 60Hz
    (31cm)    5.8 gal
    (22 L)    13.5x20
    (34.6x50.8)    25 lbs
    (11.3kg)
    K23374    KV1000    220-240V, 60Hz
    (46cm)    8.9 gal
    (34 L)    19.5x23
    (49.5x58.4)    38 lbs
    (17.2kg)
    Fisherbrand Kinematic Viscometer Tubes
    Fisherbrand Opaque Calibrated Viscometer Tubes
    Cannon-Fenske opaque type. For measuring viscosity of dark liquids and lubricating oils by ASTM D 445. Borosilicate glass. With calibration certificate. Precision ±0.3%. Holder not supplied.
    冷却器
    FISHER编号:9726-D10
    水浴冷却仪
    可将水浴锅内液体温度比室温冷却15℃;
    紧凑的设计,只有一般冷却仪的十分之一大小;
    可精确稳定的调节温度至室温及室温以下;
    将其放进恒温水浴槽上面的其中一个孔并连接电源就可直接进行操作,无需再连接其他冷却装置;
    电源大小:121 mm 宽 x 241 mm 深 x 102 mm 高 (4.75 x 9.5 x 4 inches);冷却管大小:108 mm 宽 x 190 mm 深 x 222 mm 高 (4.25 x 7.5 x 8.75 inches,包括探头长度为:572 mm (22.5-inches)。重量:5.7 kg (12.5 lbs);电源:220V,50YHZ;注意:使用环境温度不能超过80℃。
    型号CBC-100R-F
    水浴热传导硅油
    清澈,无色液体,专用于常温水浴锅作为热传导媒质。温度范围:25℃~100℃
    粘度:10 cSt
    容量:18 Liters (4.7 加仑
    9726-L30
    产地:美国CANNON
    9726-L33
    适用温度范围:80 to 135°C,粘度:20 cSt
    9726-L20
    IBF水浴专用油
    含氧化阻剂,能有效防止水浴锅在高温情况下工作时产生的变黑趋向。粘度:36 cSt 在 40°C, 5.6 cSt 在 100°C。
    注意:不要在高于135℃时使用该油剂。22.7 L (6 加仑)
    Cannon CT-2000
    •    Microprocessor-controlled temperature regulation to 150°C
    •    Built-in platinum resistance thermometer
    •    On-screen temperature monitoring
    The CANNON CT-2000 Constant Temperature Bath maintains the accurate control required by ASTM D 445 for kinematic viscosity measurements. Within the range of 20 to 100°C temperature is controlled to 0.01°C; above 100°C temperature is controlled to 0.03°C.
    Setting Temperature
    A keypad permits microprocessor-controlled temperature selection to two decimal places at any setting within the operational range of the instrument. The built-in platinum resistance thermometer continuously monitors bath temperature and displays it digitally on a four line by twenty character back-lit liquid-crystal screen. Either Celsius or Fahrenheit display of temperature may be selected. On power-up the CT-2000 performs an automatic self-test of i
  • 第3楼2004/09/30
    楼上那位好多的啊,德国SCHOTT的运动粘度计性价比较之CANNON/LAUDA高.不知你有兴趣吗?联系电话:021-58303720 陆小姐
  • 第4楼2004/10/11
    旋转粘度计因为测量范围(动态范围)宽,适应范围广泛,仪器造价相对便宜,所以,目前已经有逐渐取代毛细管粘度计之趋势,建议使用旋转粘度计。
    作为Brookfield在中国的一级代理和技术服务中心,我们提供全方位的粘度计产品,东南科仪存货量最大,销售最多的系列、型号如下:
    LVDV-III+U
    RVDV-III+U
    HADV-III+U
    HBDV-III+U
    LVDV-II+P
    RVDV-II+P
    HADV-II+P
    HBDV-II+P
    LVDV-I+
    RVDV-I+
    HADV-I+
    HBDV-I+
    LVDV-E
    RVDV-E
    HADV-E
    HBDV-E
    LVT-new
    RVT-new
    HAT-new
    HBT-new
    CAP1000+
    CAP2000+
    详细产品样本请联系索取:
    Tanglin 东南科仪
    tanglin@sinoinstrument.com
    S.E.China Sci.Equip&Serv Co. Http://www.sinoinstrument.com
    17fl, No.268 DongFengZhong Road, 510030 Guangzhou, China
    Tel:020-83510351 83510088 13902246386
    Fax:020-83510388 Zip:510030
    广州:东风中路268号广州交易广场1706  (510030)
    电话:020-83510088(十线)  83510550  83510358
    传真:020-83510388
    北京:海淀区交大东路60号舒至嘉园3座  (100044)
    电话:010-62268660  62260833  62238029
    传真:010-62238297
    东南科仪于近日签约使用中国联通CDMA大客户集群网服务,目的在于在有限资源的条件下尽量提高通话量,
    更好地为客户提供服务,并减轻因占线,客户经常打不进公司“10线83510088汇线通”固话的压力。同时,使
    用CDMA可在一定程度上保护员工特别是女性员工的身体健康。
    欢迎业务联系时拨打我公司CDMA集群网电话(特别是在固定电话占线的情况下)。
    入网的部分号码资源和使用部门情况如下:
    13380008110 经理 唐粼
    13380008111 大客户部 张小姐
    13380008112 大客户部 李小姐
    13380008113 技术服务(维修部) 刘小姐
    13380008114 技术服务咨询热线
    13380008115 商务部 周小姐
    13380008116 管理事务部 吴小姐
    13380008117 业务一部 王小姐
    13380008118 商务部 李小姐
    13380008119 销售咨询热线
    13380008120 计财部 郭小姐
    13380008121 业务二部 余小姐
    13380008122 业务二部 王先生
    13380008123 储运部 吴小姐
    13380008125 业务一部 查先生
    13380008126 业务二部 陈先生
    13380008128 业务一部 叶先生
    13380008129 业务一部 王小姐
    13380008133 经理 杨杰
    13316085820 技术服务部 谢先生
    详细情况请致电东南科仪查询。
  • luoxuepiaoxia
    第5楼2013/07/16
    请问,你们公司后来买了么?大致情况是怎样的?有空大家聊一聊,QQ44970811
  • fanchuangang
    第6楼2013/10/17
    用的不是很多,买了有七八年了,当时价格在2000元左右
