一抹冰蓝
第1楼2007/01/12
1、实验室简介
基桩能力及集成测试实验室。
2、仪器配置
跨孔式声波测录仪:型号 CSL-2;双测录系统;Olson Engineering Inc. USA 制造
除此主要单元外,系统还包括:
附加的软件:井间层析显像缺损程序(?)
一根传输探针(探头,探测器)
三根接收探针(探头,探测器)
两套100米长的电缆盘
深度编码盘
其它辅助设备:
八个可调置中器,适应内径从50毫米至150毫米的超声波测管。
100米测深钢卷尺
输出为110 V-2A DC的直流发电机
指南针
3、实验室的配套建设
由于测试需要现场完成,所以需要4轮有篷货车用于运载仪器和操作人员。实际上,这可被看做是移动实验室。
建立这类型实验室的一个重点是选择能量排放水平相匹配的右声波记录器。否则难于用来进行对大内经螺旋钻孔桩的测试,那么实验室的测试能力将会受限(同时因此限制你挣钱的能力)
(理解得是否正确,望楼主继续纠正)
poorlittle
第2楼2007/01/14
Thanks for the translation.
I would like to supplement that one of the important things in setting up this type of laboratory is the selection of right sonic logger with suitable energy emission level; otherwise, it may be difficult to perform the test for large diameter bored piles and the capacity of your laboratory will be limited (and will consequently limit your ability in earning money).
I am not good in Chinese and consider that the translation is basically correct except the following suggestions:
Cable – the cable is not made with optical fibre, but ordinary 导线 or just called 电线 (by the way, I wonder why the wireless phone is called 无绳电话, not无线电话 in Mainland China)
Crosshole – 跨孔
Centralizers adjustable to ....... - 可调置中器(?)
“100 m measuring type with weight” is not a formal term for this kind of tool (I forgot the proper name), what I mean is a 100 m 测深钢卷尺
