JayZHONG
第2楼2007/02/01
3. Gwyddion
Gwyddion is a modular program for SPM (scanning probe microscopy) data visualization and analysis. Primarily it is intended for analysis of height fields obtained by means of scanning probe microscopy techniques (AFM, MFM, STM, SNOM/NSOM), but generally it can be used for any other height field and image analysis.
下载地址:http://gwyddion.net/
JayZHONG
第3楼2007/02/01
4. GXSM
The GXSM is the Gnome X Scanning Microscopy project, it is a bit more than just a piece of software (the GXSM itself), there is full hardware support for DSP cards including open source DSP software and a growing set of SPM related electronics.
下载地址:http://gxsm.sourceforge.net/
JayZHONG
第4楼2007/02/01
5. XPMPro™ - Data aquisition, image processing and analysis
RHK's XPMPro™ software package combines all of the features from our industry leading XPMPro™ software with the user flexibility and powerful Multitasking and Dual-Monitor display capabilities of the latest versions of Windows® XP and 2000.
XPMPro™ is unprotected for image processing and analysis allowing it to be installed on multiple computers.
XPMPro™ - Demo Data - (7.85 MB zip file)
Demo data is useful for practice and to explore the capabilities of the software.
XPMPro™ - Manual - (3.26 MB zip file)
XPMPro™ - File Coversion Utility - (2.7 MB zip file)
1. Translate various file formats, such as Omicron, Digital Instruments,and Unisoku to the RHK SM3 format.
2. Translate SM3 binary header format to ASCII for export.
3. Translate SM2 files lacking the .SM2 extention to the SM3 format.
XPMPro™ - RHK Development Kit - (19.3 MB zip file)
Pre-packaged download includes:
XPMPro™, Demo Data, Manual and File Conversion Unility.
下载地址:http://www.rhk-tech.com/downloads.php
JayZHONG
第7楼2007/02/01
7. STM Simulator
瑞士Nanonis GmbH公司的软件,需要在网站上注册,注册后会偶尔给你发mail介绍他们的最新进展
The system lets you explore the various possibilities of the full SPM Control System as if it were connected to a real tunneling microscope. You can do a coarse approach, scan on a Si-111 surface, record IV curves, use the internal lock-in detector for dI/dV mapping, make a real time analysis of the noise level, and perform point spectroscopy on a grid.
A tutorial and an online help guides you step-by-step to your first image and then explores the further-going features of the system.
下载地址:http://www.nanonis.com/en/content---1--1065.html
JayZHONG
第10楼2007/02/02
8. Image J
NIH开发的免费软件,很好!!值得仔细研究研究(光镜,电镜,扫描探针显微镜研究者都可以用)
功能多多:
Autocorrelation
MRI t2 calculations
Line Analyzer
Image Correlator
Area Calculator
Particle Remover
Circularity
Modulation Transfer Function
Specify ROI
Specify Line Selection
Comment Writer
Measure Angles
16-bit Histogram
Results and Text
Draw line or point grids
Moment Calculator
Batch Statistics
Cell Counter
Oval Profile Plot
Color Comparison
Radial Profile Plot
Microscope Scale
MRI Analysis Calculator
Sync Measure 3D
Hough Circles
Convex Hull, Circularity, Roundness
Fractal Dimension and Lacunarity
Measure And Label
Colocalization
Granulometry
Texture Analysis
Named Measurements
Cell Outliner
Grid Cycloid Arc
RGB Profiler
Colocalization Finder
Spectrum Extractor
Contact Angle
RG2B Colocalization
Color Profiler
Hull and Circle
MR Urography
Template Matching
Extract IMT from ultrasound images
ITCN (Image-based Tool for Counting Nuclei)
Multi Cell Outliner
FRETcalc - FRET by acceptor photobleaching
JACoP (Just Another Co-localization Plugin)
FRET and Colocalization Analyzer
CASA (Computer Assisted Sperm Analyzer)
Radial Profile Plot Extended
下载地址:http://rsb.info.nih.gov/ij/
