★棋有慈理★
第2楼2007/02/03
这个是用来萃取样品的一个仪器,英文是这样写的:
Bottle rotator, capable of holding and rotating the extraction bottles in an end-over-end motion at a constant speed. The distance from the centre of the rotating axis to the centre of the flask shall be approximately 150 mm.
然后下面的注释栏中有说明:
Voor 't Labo, Belgium, is a supplier of a suitable product available commercially. This information is given for the convenience of users of this European Standard and does not constitute an endorsement by CEN.
雾非雾
第8楼2009/12/16
看意思,有点像翻转振荡器。
