90后检测机构质量菜鸟
第1楼2019/12/11
此意见已经生效,目前实施的只是自由贸易试验区可以进行告知承诺制度。
先行试点实施告知承诺制度。根据试点工作情况,待条件成熟后,在全国范围内推行。
具体省实施通知:详见各省市场监督管理局
以下为总局链接:http://gkml.samr.gov.cn/nsjg/rzjcs/201910/t20191025_307884.html
http://www.samr.gov.cn/xwxcs/scwfb/201911/t20191118_308596.html
Amsler测试技术
第9楼2019/12/11
阳光模拟测试系统执行的标准包括:
GR-487-CORE
Electronic Equipment Cabinets
AECTP 300 Method 305
Solar Radiation
AK LV 01
Airbag Test
ASTM E927
Standard Specification for Solar Simulation for Terrestrial Photovoltaic Testing
BMW PR 306.4
Solar Simulation for equipment parts
DBL 4571
Interior Trim Parts
DBL 5471
Covering and Form Padding Parts
DBL 7384
"Soft Feeling" Paint on Plastic Parts - Interior Components
Dessault Aviation
Solar Simulation Test
DIN EN 60068-2-5
Electrical engineering - Basic environmental testing procedures - Part 2-5: Tests - Test Sa: Simulated solar radiation at ground level
DIN EN 61646 VDE 0126-32
Thin-film terrestrial photovoltaic (PV) modules - Design qualification and type approval
DIN EN 61853-1
Photovoltaic (PV) module performance testing and energy rating - Part 1: Irradiance and temperature performance measurements and power rating
DIN IEC 68-2-9
Electrical engineering - Basic environmental testing procedures - Part 2-9: Tests - Guidance for solar radiation testing
DIN SPEC 18035-7
Sports grounds - Part 7: Synthetic turf areas
DVM 0006-EX
Exterior Lighting-Sunload
DVM 0074-MA
Ageing of interior components by sunload simulation
EN 12975-2
Thermal Collector Testing
EPA 40 CRF Part 86
Control Air Pollution from New Motor Vehicles and New Motor Vehicles Engines
Fiat 9.03141
Instrument Panels
GM 9310P
Variabel Surface temperature heat exposure test
GOST 20.57.406
Testing of Electrical Components
IEC 51345
UV Test for photovoltaic Modules
IEC 61215
Crystalline silicon terrestrial photovoltaic (PV) modules - Design qualification and type approval
IEC 904-9
Photovoltaic devices - Part 9: Solar simulation performance requirements
ISO 12097-2
Road vehicles - Airbag components - Part 2: Testing of airbag modules
JSS 5555-No.25
Enviromental Test for Electronic and Electrical equipments
LH 259001
Electronical Equipments
MIL-STD 810
