例说能力验证活动中Z值的计算
表1
参加者代码 | 检测结果 |
A | 3.28 |
B | 3.15 |
C | 3.07 |
D | 3.06 |
E | 3.26 |
F | 3.08 |
G | 3.35 |
H | 3.95 |
I | 2.94 |
J | 2.95 |
K | 3.07 |
L | 2.63 |
M | 3 |
N | 2.81 |
O | 3.39 |
P | 3.34 |
Q | 3.72 |
R | 3.33 |
S | 3.44 |
T | 2.64 |
U | 2.9 |
V | 2.98 |
W | 3.01 |
X | 2.66 |
表2
迭代步骤 | 0 | 1 | 2 |
δ=1.5s* | / | 0.4449 | 0.450328 |
x*-δ | / | 2.6251 | 2.648413 |
x*+δ | / | 3.5149 | 3.54907 |
L | 2.63 | 2.63 | 2.648413 |
T | 2.64 | 2.64 | 2.648413 |
X | 2.66 | 2.66 | 2.66 |
N | 2.81 | 2.81 | 2.81 |
U | 2.9 | 2.9 | 2.9 |
I | 2.94 | 2.94 | 2.94 |
J | 2.95 | 2.95 | 2.95 |
V | 2.98 | 2.98 | 2.98 |
M | 3 | 3 | 3 |
W | 3.01 | 3.01 | 3.01 |
D | 3.06 | 3.06 | 3.06 |
C | 3.07 | 3.07 | 3.07 |
K | 3.07 | 3.07 | 3.07 |
F | 3.08 | 3.08 | 3.08 |
B | 3.15 | 3.15 | 3.15 |
E | 3.26 | 3.26 | 3.26 |
A | 3.28 | 3.28 | 3.28 |
R | 3.33 | 3.33 | 3.33 |
P | 3.34 | 3.34 | 3.34 |
G | 3.35 | 3.35 | 3.35 |
O | 3.39 | 3.39 | 3.39 |
S | 3.44 | 3.44 | 3.44 |
Q | 3.72 | 3.5149 | 3.5149 |
H | 3.95 | 3.5149 | 3.5149 |
平均值 | 3.125416667 | 3.098742 | 3.099859 |
标准差 | 0.320271341 | 0.264743 | 0.262715 |
新的x* | 3.07 | 3.098742 | 3.099859 |
新的s* | 0.2966 | 0.300219 | 0.297919 |
由此可知,最终的x*为3.10,s*为0.30 |
表3
参加者代码 | 检测结果 | Z值 |
A | 3.28 | 0.6 |
B | 3.15 | 0.17 |
C | 3.07 | -0.1 |
D | 3.06 | -0.13 |
E | 3.26 | 0.53 |
F | 3.08 | -0.07 |
G | 3.35 | 0.83 |
H | 3.95 | 2.83 |
I | 2.94 | -0.53 |
J | 2.95 | -0.5 |
K | 3.07 | -0.1 |
L | 2.63 | -1.57 |
M | 3 | -0.33 |
N | 2.81 | -0.97 |
O | 3.39 | 0.97 |
P | 3.34 | 0.8 |
Q | 3.72 | 2.07 |
R | 3.33 | 0.77 |
S | 3.44 | 1.13 |
T | 2.64 | -1.53 |
U | 2.9 | -0.67 |
V | 2.98 | -0.4 |
W | 3.01 | -0.3 |
X | 2.66 | -1.47 |
2.2四分位距法计算Z值
四分位间距法结合EXCEL表格,计算Z值如表4。
表4
参加者代码 | 检测结果 | Z值 |
A | 3.28 | 0.74 |
B | 3.15 | 0.28 |
C | 3.07 | 0 |
D | 3.06 | -0.04 |
E | 3.26 | 0.67 |
F | 3.08 | 0.04 |
G | 3.35 | 0.98 |
H | 3.95 | 3.08 |
I | 2.94 | -0.46 |
J | 2.95 | -0.42 |
K | 3.07 | 0 |
L | 2.63 | -1.54 |
M | 3 | -0.26 |
N | 2.81 | -0.91 |
O | 3.39 | 1.12 |
P | 3.34 | 0.95 |
Q | 3.72 | 2.28 |
R | 3.33 | 0.91 |
S | 3.44 | 1.3 |
T | 2.64 | -1.51 |
U | 2.9 | -0.6 |
V | 2.98 | -0.32 |
W | 3.01 | -0.21 |
X | 2.66 | -1.44 |
在EXCEL表格中求中位值和标准化四分位距可以采用EXCEL表格中的函数功能: 中位值:采用统计函数中的MEDIAN函数; 下四分位数(Q1):统计函数中QUARTILE函数,1; 上四分位数(Q3):统计函数中QUARTILE函数,3。 |
3结语
有上述的计算过程可以看出,二者对同一批数据的处理,标准化四分位距法比算法A的计算过程要简单,但是二者所得结果上有一定的差距,这是今后需要进行讨论的。
参考文献:
CNAS-GL002:2018《能力验证结果的统计处理和能力评价指南》
