急求文献5篇
  • 人在江湖
    2020/07/08
文献检索-互助
  • 悬赏金额:50积分状态:已解决
  • 注意需要正式版本带页码
    【序号】:1
    【作者】:Yi Zhang,a Jie Xu,a Lin Lv,bc Aiwu Wang,d Baoshun Zhang,b Yigang Dinga and Chundong Wang
    【题名】:Electronic engineering of CoSe/FeSe2 hollow nanospheres for efficient water oxidation
    【期刊】:Nanoscale
    【年、卷、期、起止页码】:Issue 18, 2020
    【全文链接】:https://pubs.rsc.org/en/Content/ArticleLanding/NR/2020/D0NR01809K#!divAbstract
    【序号】:2
    【作者】:Changyan Yang, Rui Li, Qi Qiu, Hui Yang, Youhong Zhang, Bohan Yang, Jinsheng Wu, Bo Li, Wei Wang, Yigang Ding, Bo Zhang
    【题名】:Pyrolytic behaviors of Scenedesmus obliquus over potassium fluoride on alumina
    【期刊】:
    【年、卷、期、起止页码】:
    Volume 263, 1 March 2020, 116724
    【全文链接】:https://www.sciencedirect.com/science/article/pii/S0016236119320782
    【序号】:3
    【作者】:Bingwen Long,Suwen Chen,Zuhong Li,Yigang Ding
    【题名】:Solubility of ammonium fluoride in aqueous sodium fluoride solutions of various concentrations from dilute to saturated at 298.15 K for fluorine recovery from wet-process phosphoric acid【期刊】:Journal of Molecular Liquids
    【年、卷、期、起止页码】:Volume 299, 1 February 2020, 112247
    【全文链接】:https://www.sciencedirect.com/science/article/abs/pii/S0167732219325310
    【序号】:4
    【作者】:Chunpeng Xiang,a Yanhua Xiao,‡a Hang Bai,a Xia Yin,a Meng Peng,a Xiaojun Yang,ab Yigang Dinga and Zhiping Du
    【题名】:Fabrication of a highly dispersed/active Pd nanoparticle supported catalyst: a cation-assisted reduction method in ethylene glycol–water solution at mild temperature
    【期刊】:nanoscale
    【年、卷、期、起止页码】:Issue 6, 2020
    【全文链接】:https://pubs.rsc.org/en/content/articlelanding/2020/nr/c9nr10760f#!divAbstract
    【序号】:5
    【作者】:Bingwen Long, Zuhong Li, Tong Li, Yigang Ding
    【题名】:Characterization of the solubility of m-phthalic acid in co-solvent mixture of acetone and ethanol at different temperatures
    【年、卷、期、起止页码】:Volume 296, 15 December 2019, 111759
    【全文链接】:https://www.sciencedirect.com/science/article/abs/pii/S0167732219333999
  • dong3626
    第1楼2020/07/08
    111111111111111111111111111
  • dong3626
    第2楼2020/07/08
    44444444444444444444
  • dong3626
    第4楼2020/07/09
    222222222222222222222222222222
  • dong3626
    第5楼2020/07/09
    3333333333333333333333333333
  • dong3626
    第6楼2020/07/09
    555555555555555555555555555555
