When you’re part of the team at Thermo Fisher Scientific, you’ll do important work. Surrounded by collaborative colleagues, you’ll have the support and opportunities that only a global leader can give you. Our respected, growing organization has an exceptional strategy for the near term and beyond. Take your place on our strong team and help us make significant contributions to the world.
Position Summary: The Applications Validation Engineer will be responsible for testing various life science samples with the NanoDrop and Core UV-Vis spectrophotometer product lines. This position requires a validation engineer with knowledge and experience in laboratory instrumentation and software. He/she must be capable of both doing laboratory work and critically analyzing experimental results. Applications Validation Engineer also participate in new product development and R&D activities. Essential Duties and Responsibilities: • Uses expertise in molecular biology and other fields relevant to spectroscopy to produce and document experimental data. • Uses expertise in chemistry to generate samples for testing performance on our spectrophotometers. • Works with the R&D Division to help generate data to support R&D projects. • Translate VOC “Voice of Customer” requirements into performance requirements and software requirements. • Other miscellaneous duties as assigned Specific Scope Data: • Perform and document R&D testing activities. Minimum Education and Experience Requirements: • Master’s Degree in life sciences, physical science, chemistry, or engineering discipline. • Experience in molecular biology is desirable. • Relevant experience in the development and/or applications of spectroscopic techniques is highly desirable. • Ideal candidate will have some experience working with routine molecular biology laboratory techniques. Knowledge, Skills, and Abilities necessary to perform essential functions: • High level of technology fluency to understand and properly communicate the technology associated with assigned products. • High energy level with ability to take initiative. • Proven reasoning abilities and sound judgment. • Must possess excellent verbal and written communication skills. • Windows and MS Office proficiency. • Programming experience with macros or other workflow capabilities is preferred. • Process-oriented with demonstrated attention to details. Delivering results on time is essential. • Teamwork-oriented with collaborative style. • Demonstrated proficiency of Thermo Fisher Scientific values – Integrity, Intensity, Innovation and Involvement
