NicoCage 2020/10/30
色谱柱:DB-5ms Ultra Inert 122-5512UI 进样器:Agilent 7683B, 5uL进样针,1.0uL不分流进样,柱上每种组分进样5ng 载气:氦气,72cm/s,恒流 进样口:脉冲不分流进样,325℃,1.5min前压力维持在20psi,2.0min时吹扫流量为50ml/min 柱温箱:以17℃/min从150℃升至325℃,保持5min 检测器:MSD离子源温度300℃,四极杆温度150℃,传输线温度300℃,扫描范围200-1000amu
