求助,怎么选择透射斑位置
透射电镜(TEM)
  • 新手求助,请问怎样选择衍射点呀,透射点附近的三个点是哪个呀,这些光斑都能组成平行四边形啊,
    材料是α-MnO2,标准卡片是PDF#44-0141: 求助大家帮我看下吧
    QM=Common(+); d=Diffractometer; I=(Unknown)
    Manganese Oxide
    MnO2
    Radiation=CuKa1 Lambda=1.5406 Filter=
    Calibration= 2T=12.784-120.913 I/Ic(RIR)=
    Ref: Level-1 PDF
    Tetragonal, I4/m(87) Z=8 mp=
    CELL: 9.7847 x 9.7847 x 2.863 <90.0 x 90.0 x 90.0> P.S=
    Density(c)=4.21 Density(m)= Mwt= Vol=274.1
    Ref: Ibid.
    Strong Lines: 2.39/X 3.09/8 1.53/6 4.89/5 1.83/5 6.92/4 1.35/4 1.63/3
    2-Theta d(?) I(f) ( h k l ) Theta 1/(2d) 2pi/d n^2
    12.784 6.9190 37.0 ( 1 1 0) 6.392 0.0723 0.9081
    18.107 4.8950 53.0 ( 2 0 0) 9.054 0.1021 1.2836
    25.711 3.4620 5.0 ( 2 2 0) 12.856 0.1444 1.8149
    28.841 3.0930 82.0 ( 3 1 0) 14.421 0.1617 2.0314
    36.696 2.4470 24.0 ( 4 0 0) 18.348 0.2043 2.5677
    37.522 2.3950 100.0 ( 2 1 1) 18.761 0.2088 2.6235
    39.010 2.3070 9.0 ( 3 3 0) 19.505 0.2167 2.7235
    41.225 2.1880 5.0 ( 4 2 0) 20.613 0.2285 2.8717
    41.968 2.1510 28.0 ( 3 0 1) 20.984 0.2325 2.9211
    46.037 1.9699 2.0 ( 3 2 1) 23.018 0.2538 3.1896
    47.373 1.9174 8.0 ( 5 1 0) 23.686 0.2608 3.2769
    49.864 1.8273 50.0 ( 4 1 1) 24.932 0.2736 3.4385
    52.855 1.7307 1.0 ( 4 4 0) 26.428 0.2889 3.6304
    56.372 1.6308 29.0 ( 6 0 0) 28.186 0.3066 3.8528
    56.927 1.6162 10.0 ( 4 3 1) 28.464 0.3094 3.8876
    60.274 1.5342 58.0 ( 5 2 1) 30.137 0.3259 4.0954
    65.108 1.4315 15.0 ( 0 0 2) 32.554 0.3493 4.3892
    66.691 1.4013 1.0 ( 1 1 2) 33.346 0.3568 4.4838
    67.648 1.3838 1.0 ( 7 1 0) 33.824 0.3613 4.5405
    68.185 1.3742 5.0 ( 2 0 2) 34.092 0.3638 4.5722
    69.711 1.3478 35.0 ( 5 4 1) 34.856 0.3710 4.6618
    71.189 1.3234 1.0 ( 2 2 2) 35.595 0.3778 4.7478
    72.711 1.2994 8.0 ( 3 1 2) 36.356 0.3848 4.8355
    73.700 1.2844 3.0 ( 7 3 0) 36.850 0.3893 4.8919
    77.160 1.2352 4.0 ( 4 0 2) 38.580 0.4048 5.0868
    78.588 1.2163 10.0 ( 3 3 2) 39.294 0.4111 5.1658
    83.818 1.1532 2.0 ( 6 6 0) 41.909 0.4336 5.4485
    84.348 1.1473 3.0 ( 5 1 2) 42.174 0.4358 5.4765
    87.148 1.1175 2.0 ( 7 4 1) 43.574 0.4474 5.6225
    91.462 1.0757 9.0 ( 6 0 2) 45.731 0.4648 5.8410
    101.470 0.9949 2.0 ( 7 1 2) 50.735 0.5026 6.3154
    102.905 0.9849 1.0 ( 6 4 2) 51.452 0.5077 6.3795
    104.362 0.9751 2.0 ( 8 5 1) 52.181 0.5128 6.4436
    111.406 0.9324 6.0 ( 2 1 3) 55.703 0.5363 6.7387
    118.135 0.8980 2.0 ( 6 6 2) 59.067 0.5568 6.9969
    120.913 0.8854 5.0 ( 4 1 3) 60.456 0.5647 7.0964
  • WYASBY
    第1楼2021/08/12
    我看一些教程里面衍射图上没有挡针,透射点的位置是空的,这是咋回事呀
  • dahua1981
    第2楼2021/08/12
    学透射不可错过的最全衍射斑点分析与标定资料,基础且深度
    http://www.cailiaoniu.com/207472.html
  • 我不是龙哥
    第3楼2021/08/12
    个别的用针挡住是为了降低透射斑对衬度的影响,也是为了保护CCD不被烧坏!标定时也不必非要从实际的透射点开始量,重要的是对应的晶面间距和夹角,你再旁边找一个点开始量,取最短加次最短矢量构成一个平行四边形进行标定,只要晶面间距和对应的晶面夹角能够自洽,也就不影响标定结果,不过最终标指数时还是要围绕实际透射斑!
  • WYASBY
    第4楼2021/11/09
    我不是龙哥(m3002960) 发表:个别的用针挡住是为了降低透射斑对衬度的影响,也是为了保护CCD不被烧坏!标定时也不必非要从实际的透射点开始量,重要的是对应的晶面间距和夹角,你再旁边找一个点开始量,取最短加次最短矢量构成一个平行四边形进行标定,只要晶面间距和对应的晶面夹角能够自洽,也就不影响标定结果,不过最终标指数时还是要围绕实际透射斑
    您好,我用旁边的一个平行四边形标定了,晶面间距和标准卡片能够吻合,但是晶面夹角我不太确定该怎样比对,标定结果的夹角是几个点分别与中心点的夹角,是不是还需要转换成2个衍射点之间的夹角呀,比如说2,3点之间的夹角需要通过2,3点分别与衍射斑的夹角计算出来,然后再通过计算晶面和cosθ的关系得到两个晶面夹角去验证呀?验证完如果没错的话请问该怎么去参考实际衍射斑呢,感觉这个针不仅遮挡了衍射斑,还遮住了好几个衍射点,最后该怎么确定衍射斑的位置呢?
    还有一个问题想请教一下,确定衍射斑后,选取衍射点是按照平行四边形法则选择3个矢量点吗,为什么看一些教程里面衍射点选了好些个,也没有什么规律,像下面这个图里,选择2,3,4点就可以了吧,为啥还要选1呢?正确的该怎样做呢
  • imrszl
    第5楼2021/11/11
    看上去踩得还蛮正,我的话会这样。 然后再根据衍射斑点构成的基矢去确认一下。
  • 我不是龙哥
    第6楼2021/11/12
    就像上面同学说的那样,根据衍射衬度对称性(衍射已经比较正)就可以知道实际透射斑的位置。然后选择最短矢量及次最短矢量R1、R2,也就是选择了二维点阵的基矢量,测量夹角及长度,算出晶面间距去对比,如上图R1、R2取倒数得到的晶面间距对应的晶面应该是200和101,然后再根据R1、R2夹角筛选合适的晶面指数就行了。标的时候200被挡住了,那可以标400啊。一般说来就标一对基矢量就够了,因为根据周期性别的点都可以根据基矢量算出来。
    WYASBY(Insm_cc46d0ac) 发表:
