jun来也
第5楼2007/09/23
貌似美国铝标准号为AA打头的吧?楼主的这个标准号应该是错了。
能否给确定是哪个标准号及名称?有内容提示更好,以方便大家更好的查找。
AA 美国铝标准目录
AA-15-1995 ALUMINUM FORGING DESIGN MANUAL - SECOND EDITION
AA-16-1988 ALUMINUM IMPACTS DESIGN MANUAL AND APPLICATION GUIDE
AA-19-1969 SPECIAL REPORT ON THE MECHANICAL PROPERTIES OF PERMANENT MOLD ALUMINUM ALLOY TEST CASTINGS
AA-19-1969 SPECIAL REPORT ON THE MECHANICAL PROPERTIES OF SAND CAST ALUMINUM ALLOY TEST CASTINGS
AA-65-1984 REPAIR & MAINTENANCE OF ALUMINUM RAILCARS
AA-67-1983 ALUMINUM DRAINAGE PRODUCTS MANUAL
AA-94-1990 ALUMINUM STATISTICAL REVIEW FOR 1989
AA-95-1985 ALUMINUM RECYCLING CASEBOOK
AA-ABC-1997 ALUMINUM IN BRIDGE CONSTRUCTION: PERSPECTIVE ON DESIGN, CONSTRUCTION AND PERFORMANCE
AA-ABH21-1990 ALUMINUM BRAZING HANDBOOK FOURTH EDITION
AA-ADM-105-2005 ALUMINUM DESIGN MANUAL - ERRATA: 01/05
AA-AEM-1-1998 ALUMINUM EXTRUSION MANUAL - THIRD EDITION
AA-AF-1981 ALUMINUM FOIL ADDENDUM - 1986
AA-AFM04-2004 ALUMINUM FOIL MANUAL
AA-AHCI-1-2003 ALUMINUM AND HEALTH A REVIEW OF THE ISSUES, THE EFFORTS AND THE KNOWLEDGE - FIFTH EDITION
AA-AIECWP-1990 ALUMINUM INDUSTRY ENERGY CONSERVATION WORKSHOP XI PAPERS
AA-AIRAM-1999 ALUMINUM INDUSTRY ROADMAP FOR THE AUTOMOTIVE MARKET ENABLING TECHNOLOGIES AND CHALLENGES FOR BODY STRUCTURES AND CLOSURES
AA-AIV-2001 ALUMINUM INDUSTRY VISION SUSTAINABLE SOLUTIONS FOR A DYNAMIC WORLD
AA-ALATR-1-2001 ALUMINA TECHNOLOGY ROADMAP
AA-AMSST-1999 A METHOD OF STRESS-STRAIN TESTING OF ALUMINUM CONDUCTOR AND ACSR AND A TEST FOR DETERMINING THE LONG TIME TENSILE CREEP OF ALUMINUM CONDUCTORS IN OVERHEAD LINES
AA-APBS-1994 ALUMINUM'S POTENTIAL BRIDGE CONSTRUCTION THE PROCEEDINGS OF THE BRIDGE SESSION OF THE 1994 ALUMITECH CONFERENCE
AA-APC-1996 ALUMINUM-PIGMENTED COATINGS FOR INDUSTRIAL MAINTENANCE APPLICATIONS
AA-ARC-1998 ALUMINUM RECYCLING CASEBOOK - SEVENTH EDITION
AA-ASD-1(M)-2003 ALUMINUM STANDARDS AND DATA 2003 METRIC SI
AA-ASD-1-2003 ALUMINUM STANDARDS AND DATA 2003
AA-ASH22-2004 ALUMINUM SOLDERING HANDBOOK
AA-ASM35-2000 SPECIFICATIONS FOR ALUMINUM SHEET METAL WORK IN BUILDING CONSTRUCTION CONSTRUCTION MANUAL SERIES SECTION 5 - FOURTH EDITION
AA-AT-2-1998 LIFE CYCLE INVENTORY REPORT FOR THE NORTH AMERICAN ALUMINUM INDUSTRY
AA-AT-3-1998 ALUMINUM FOR AUTOMOTIVE BODY SHEET PANELS
AA-AT-4-1998 PRACTICES FOR THE REPAIR OF AUTOMOTIVE SHEET ALUMINUM
AA-AT-5-1998 AUTOMOTIVE ALUMINUM CRASH ENERGY MANAGEMENT MANUAL
AA-AT-6-1998 ALUMINUM AUTOMOTIVE EXTRUSION MANUAL
AA-AT-7-2001 ALUMINUM: THE COROSION RESISTANT AUTOMOTIVE MATERIAL
AA-ATECH-2003 ALUMINUM INDUSTRY TECHNOLOGY ROADMAP
AA-ATRF-1997 ALUMINUM TECHNOLOGY ROADMAP WORKSHOP
AA-ATRM-5-2003 ALUMINUM INDUSTRY TECHNOLOGY ROADMAP
AA-ATS-1-1994 ROLLING TECHNOLOGY SESSIONS AT ALUMITECH '94 SHEET & PLATE INGOT CASTING FOIL
AA-AWG51-1997 ALUMINUM ALLOY BUILDING WIRE INSTALLATION MANUAL AND DESIGN GUIDE
AA-C-6-2004 ALUMINUM AND ITS ALLOYS - THIRD EDITION
AA-CA92-2002 CARE OF ALUMINUM - SIXTH EDITION
AA-CCW-50-1999 CODE WORDS FOR OVERHEAD ALUMINUM ELECTRICAL CONDUCTORS - SEVENTH EDITION
AA-CFC60-1994 GUIDELINES FOR THE USE OF ALUMINUM WITH FOOD AND CHEMICALS COMPATIBILITY DATA ON ALUMINUM IN THE FOOD AND CHEMICAL PROCESS INDUSTRIES - SIXTH EDITION
AA-CRU-49-1999 CODE WORDS FOR UNDERGROUND DISTRIBUTION CABLES - THIRD EDITION
AA-CRYO-1999 ALUMINUM ALLOYS FOR CRYOGENIC APPLICATIONS
AA-CWU49-1984 CODE WORDS FOR UNDERGROUND DISTRIBUTION CABLES
AA-CWU-49-1999 CODE WORDS FOR UNDERGROUND DISTRIBUTION CABLES - THIRD EDITION
jun来也
第6楼2007/09/23
AA-DAF45-2003 DESIGNATION SYSTEM FOR ALUMINUM FINISHES
AA-DSE2-1998 DRAFTING STANDARDS FOR ALUMINUM EXTRUDED PRODUCTS - NINTH EDITION
AA-ELC54-1998 THE EVALUATION OF LOSSES IN CONDUCTORS
AA-EU-1-1997 END USE GUIDE FOR REPORTING SHIPMENTS FOR SEMIFABRICATED ALUMINUM PRODUCTS FOR 1998
AA-EXPD-1-2000 NORTH AMERICAN ALUMINUM INDUSTRY EXTRUSION PRESS DIRECTORY
AA-F-1-2000 GUIDELINES FOR HANDLING ALUMINUM FINES GENERATED DURING VARIOUS ALUMINUM FABRICATING OPERATIONS
AA-FDM15-2004 ALUMINUM FORGING DESIGN MANUAL - SECOND EDITION
AA-FMA-17-1988 FORMING AND MACHINING ALUMINUM
AA-GMA69-2002 GUIDELINES FOR HANDLING MOLTEN ALUMINUM - THIRD EDITION
AA-GSC-1998 GUIDELINES FOR ALUMINUM SOW CASTING AND CHARGING
AA-GSR-2002 GUIDELINES FOR ALUMINUM SCRAP RECEIVING AND INSPECTION D ON SAFETY AND HEALTH CONSIDERATIONS - SECOND EDITION
AA-HR94-2004 ALUMINUM STATISTICAL REVIEW FOR 2003
AA-IAR-1998 INERT ANODE ROADMAP
AA-LTG1-2003 COMPONENTS OF CLAD ALUMINUM ALLOY PRODUCTS - SECOND EDITION
AA-MJM-1997 MATERIALS JOINING MONOGRAPH ALUMINUM AND ALUMINUM ALLOYS
AA-NSSF-1996 NON-SPECULAR SURFACE FINISH ON BARE OVERHEAD ALUMINUM CONDUCTORS
AA-OR-1-2000 INTERNATIONAL DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR UNALLOYED ALUMINUM - SUPERSEDES: 1998 EDITION
AA-OR1-2003 REGISTRATION RECORD SERIES INTERNATIONAL DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR UNALLOYED ALUMINUM
AA-PAH-3-1994 PROCEEDINGS OF THE THIRD INTERNATIONAL CONFERENCE ON ALUMINUM AND HEALTH
AA-PD-1-2001 U.S ALUMINUM INDUSTRY PLANT DIRECTORY - SECOND EDITION
AA-PK-1-2002 DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR ALUMINUM ALLOYS IN THE FORM OF CASTINGS AND INGOT
AA-PTF-1996 ALUMINUM INDUSTRY: INDUSTRY/GOVERNMENT PARTNERSHIPS FOR THE FUTURE
AA-QCA-1-2002 VISUAL QUALITY ATTRIBUTES OF ALUMINUM SHEET AND PLATE - FOURTH EDITION
AA-QCA-2-1993 VISUAL QUALITY CHARACTERISTICS OF ALUMINUM EXTRUSIONS - FIRST EDITION
AA-REG-1-2000 DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR ALUMINUM HARDENERS
AA-REG-3-1993 REGISTRATION RECORD OF ALUMINUM ASSOCIATION DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR WROUGHT ALUMINUM AND WROUGHT ALUMINUM ALLOYS
AA-REG-4-1998 REGISTRATION RECORD SERIES INTERNATIONAL ALLOY DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR WROUGHT ALUMINUM AND WROUGHT ALUMINUM ALLOYS; UNIFIED NORTH AMERICAN AND INTERNATIONAL REGISTRATION RECORDS
AA-SPC18-2000 STANDARDS FOR ALUMINUM SAND AND PERMANENT MOLD CASTINGS - 14TH EDITION; ERRATA
AA-SSCC-1997 STRESS-STRAIN-CREEP- CURVES FOR ALUMINUM OVERHEAD ELECTRICAL CONDUCTORS
AA-SUP-1-1995 UNDERSTANDING ALUMINUM EXTRUSION TOLERANCES - SECOND EDITION
AA-T17-1969 ALUMINUM: THE CORROSION RESISTANT AUTOMOTIVE MATERIAL
AA-TAN-1-2001 TEMPERS FOR ALUMINUM AND ALUMINUM ALLOY PRODUCTS METRIC EDITION
AA-TEAL-1-2004 INTERNATIONAL ALLOY DESIGNATIONS AND CHEMICAL COMPOSITION LIMITS FOR WROUGHT ALUMINUM AND WROUGHT ALUMINUM ALLOYS
AA-TH56-1989 ALUMINUM ELECTRICAL CONDUCTOR HANDBOOK - THIRD EDITION
AA-TP-1-1990 STANDARD TEST PROCEDURE FOR ALUMINUM ALLOY GRAIN REFINERS
AA-TP-2-1990 STANDARD TEST PROCEDURE FOR MEASURING THE DISSOLUTION OF ALUMINUM HARDENERS
AA-TR-2-2003 RECOMMENDATIONS FOR STORAGE AND HANDLING OF ALUMINUM POWDERS AND PASTE
AA-TR3-2004 GUIDELINES FOR MINIMIZING WATER STAINING OF ALUMINUM - FOURTH EDITON
AA-TR7-1981 GUIDELINES FOR IN-PLANT HANDLING OF ALUMINUM SHEET AND PLATE
AA-TRBR-2000 TECHNOLOGY ROADMAP FOR BAUXITE RESIDUE TREATMENT AND UTILIZATION
AA-WATP23-2002 WELDING ALUMINUM: THEORY AND PRACTICE - FOURTH EDITION
AA-YL-1-2001 TEMPERS FOR ALUMINUM AND ALUMINUM ALLOY PRODUCTS
ANSI/AA-H35.1(M)-2004 ALLOY AND TEMPER DESIGNATION SYSTEMS FOR ALUMINUM
ANSI/AA-H35.1-2004 ALLOY AND TEMPER DESIGNATION SYSTEMS FOR ALUMINUM
ANSI/AA-H35.2(M)-2003 DIMENSIONAL TOLERANCES FOR ALUMINUM MILL PRODUCTS
ANSI/AA-H35.2-2003 DIMENSIONAL TOLERANCES FOR ALUMINUM MILL PRODUCTS
ANSI/AA-H35.3-2003 DESIGNATION SYSTEM FOR ALUMINUM HARDENERS
ANSI/AA-H35.4-2003 DESIGNATION SYSTEM FOR UNALLOYED ALUMINUM
ANSI/AA-H35.5-2003 NOMENCLATURE SYSTEM FOR ALUMINUM METAL MATRIX COMPOSITE MATERIALS
