展品范围: Measuring devices and equipment: instruments for determining the composition of substances and materials (portable, laboratory and industrial); scales and weighing dosers; chemical sensors instruments for monitoring the quality of oil products; instruments for determining viscosity; instruments and equipment for chromatography; thermometers; instruments and equipment for determining the structure of substances and materials; instruments and equipment for environmental parameters' measuring; instruments for electrochemical analysis; instruments and equipment for spectrometry (X-ray, NMR, optical, etc.); instruments for nuclear physics research; portable and stationary analyzers of toxic and explosive substances and drugs; flow meters, level gauges; instruments for determining the density of materials and liquids; instruments for melting points determining; instruments for materials humidity control; instruments and equipment for testing of liquid and gas permeability of materials; pressure gauges.
Auxiliary laboratory equipment: thermostat equipment; equipment for controlled working environment creating; gas equipment and generators of pure gases; equipment for liquid dosing and transfer; equipment for sampling and preparation of tests for analysis; vacuum equipment (vacuum pumps, fittings, flanges, gates, vacuum gauges and helium leak detectors); laboratory equipment for water purification; drying equipment; laboratory furniture; exhaust hoods and laminar boxings; laboratory supplies.
Reagents and materials: chemical reagents; highly purified chemical substances; indicators, standard models, custom-made reagents; gases and gas mixtures; filters and solvents; test systems.
Analytical laboratory supporting means: Design and construction of laboratory premises, clean area and isolation wards; Climate control, air conditioning; Special clothes for laboratory staff; Individual protection facilities; Education and training of analytical laboratory staff.
Laboratory research automation means: Robot-aided laboratory equipment; Software for all laboratory analyses; Laboratory information systems.
Full outfitting of laboratories: mobile and field laboratories for chemical and analytical monitoring. new ecological monitoring technology; new analytical control technologies and procedures; standardization, certification, and technical regulations; accreditation of test laboratories; measuring equipment testing (calibrating) services and attestation of testing equipment; analytical laboratory services; information services for laboratories.
展会介绍: On April 10 - 13, 2007 Sokolniki Culture & Exhibition Centre in Moscow will host the 5th Jubilee specialized exhibition of analytical equipment, control and measuring devices, laboratory furniture and chemical agents A-TESTex (Analytica). Four previous years the exhibition was held under the name AnalyticaExpo.
