Cadmium and its compounds in electrical contacts and cadmium plating except for applications banned under Directive 91/338/EEC (1) amending Directive 76/769/EEC (2) relating to restrictions on the marketing and use of certain dangerous substances and preparations. 是不是所有电触点中的镉都可以豁免?后面的except for 从句是不是只修饰镉镀层的?
hya97发表:Cadmium and its compounds in electrical contacts and cadmium plating except for applications banned under Directive 91/338/EEC (1) amending Directive 76/769/EEC (2) relating to restrictions on the marketing and use of certain dangerous substances and preparations. 是不是所有电触点中的镉都可以豁免?后面的except for 从句是不是只修饰镉镀层的?
