X-ray photoelectron spectroscopic studies of electrode surfaces using a new controlled transfer technique: Part II. Results for a molybdenum electrode and the curve fitting procedure
【序号】:2 【作者】:R.O. Ansell, T. Dickinson, A.F. Povey, P.M.A. Sherwood 【题名】:X-ray photoelectron spectroscopic studies of electrode surfaces using a new controlled transfer technique: Part II. Results for a molybdenum electrode and the curve fitting procedure 【期刊】:Journal of Electroanalytical Chemistry and Interfacial Electrochemistry, Volume 98, Issue 1, Pages 79-89 (10 April 1979) 【全文链接】:https://www.sciencedirect.com/science/article/abs/pii/S0022072879802867?via%3Dihub
