【求助】USP29剂量单位均匀性翻译求助
文献检索-互助
  • 对不起,我找不到我要到的版面...帮我转下吧 ....谢谢!
    Select not less than 30 units, and proceed as follows for the dosage form designated. Where the amount of drug substance in a single dosage unit differs from that required in the Assay, adjust the degree of dilution of the solutions and/or the volume of aliquots so that the concentration of the drug substances in the final solution is of the same order as that obtained in the Assay procedure;
