→ 全球1000Hz电磁共振疲劳试验机,GIGAFORTE 50 The GIGAFORTE 50 was specially developed for tests in the VHCF regime. With the test frequency of 1000 Hz tests with more than 100 millions of load cycles can be done in a reasonable time. It is possible to test standard samples or small components load or strain controlled. Technical data:
