Winchester射频微波BNC系列连接器
  • Ins_53b266b9
    2024/04/08
其他仪器综合讨论
  • BNC连接器是用于射频终端同轴电缆的连接器。全称为Bayonet Nut Connector(刺刀螺母连接器)。BNC电缆连接器由中心销、外套管和支架组成,包括BNC连接器底座、外套管和探头。由于同轴电缆的广泛应用,BNC连接器在通信系统中也得到了广泛的应用,例如,网络设备中的E1接口通过同轴电缆与两个BNC连接器连接。还经常用于在高端显示器和音频设备中传输音频和视频信号。
    Winchester是一家高可靠性连接器制造厂商,具备AS9100AS7003航空航天质量体系认证,为全球客户提供同轴线缆、微波连接器产品。其产品被广泛应用于军用、航空航天、通信测试领域。
    深圳市立维创展科技有限公司,授权代理Winchester连接器产品,欢迎咨询。
    详情了解Winchester请点击:/brand/79.html
    或联系我们的销售工程师:0755-83642657 QQ: 2295048674
    Part #
    Description
    Max Frequency
    TRU-12824
    BNC(m) to QDS(f) Right Angle Adapter
    4 GHz
    TRU-11705
    BNC(m) REPLACEABLE CONNECTOR
    4 GHz
    TRU-11706
    BNC(f) REPLACEABLE CONNECTOR
    4 GHz
    TRU-11694
    BNC(f) TO SMA(m) Adapter, Straight
    4 GHz
    TRU-11695
    BNC(m) TO N(f) Adapter, Straight
    4 GHz
    TRU-11696
    BNC(m) TO N(m) Adapter, Straight
    4 GHz
    TRU-11697
    BNC(m) TO N(f) Adapter, Right Angle
    4 GHz
    TRU-11698
    BNC(f) TO N(m) Adapter, Straight
    4 GHz
    TRU-11699
    BNC(m) TO BNC(m) Adapter, Straight
    4 GHz
    TRU-11700
    BNC(f) TO BNC(f) Adapter, Straight
    4 GHz
    TRU-11693
    BNC(f) TO SMA(f) Adapter, Straight
    4 GHz
    TRU-11691
    BNC(m) TO SMA(m) Adapter, Straight
    4 GHz
    TRU-11692
    BNC(m) TO SMA(f) Adapter, Straight
    4 GHz
    SBC8281
    BNC BROADCAST GRADE BELD 8281
    4 GHz
    361P704
    BNC Vertical PCB Jack 75OHM TEF
    4 GHz
    361ES504EFT
    E-SNAP BNC Female 50 OHM
    4 GHz
    351A505
    Adapter, BNC Right Angle J/P
    4 GHz
    335R544
    Adapter, BNC ISOLATED Bulkhead F/F
    4 GHz
    335A544
    Adapter, BNC Bulkhead J/J
    4 GHz
    332A705
    Adapter, BNC F/F BARREL 75 OHM
    4 GHz
    3319505
    Adapter, BNC Male TO SMA FEMAL
    4 GHz
    3318505
    Adapter, BNC Plug TO F Jack
    4 GHz
    3309505
    Adapter, BNC Male TO SMA Male
    4 GHz
    326R515
    BNC ISOLATED Bulkhead Jack
    4 GHz
    310A205FS
    BNC Cable Plug (RG58 SOLID)
    4 GHz
    310A205F
    BNC Cable Plug, RG58 (STRANDED)
    4 GHz
    364A2595
    X-2 DUAL BNC Jacks Right Angle WHITE
    4 GHz
    361VH704EFT
    BNC V-BITE Female-4GHZ
    4 GHz
    361V704ER
    BNC V-BITE,75 OHM,TEFLON,GOLD PIN
    4 GHz
    364M795L
    BNC Right Angle PC Jack-METAL LO-PROFI
    4 GHz
    364M595L
    BNC Right Angle PC Jack, LOW PROF METAL
    4 GHz
    364M595
    BNC Right Angle PC Jack, STD PROF METL
    4 GHz
    364M2795
    X-2 DUAL BNC Right Angle Jacks METAL 75 OHM
    4 GHz
    364M2595
    X-2 DUAL BNC Right Angle PCB Jacks METAL
    4 GHz
    364A795BL
    BNC Right Angle PC Jack, 75OHM,LOWPD,WHT
    4 GHz
    372B006
    BNC CAP & CHAIN
    4 GHz
    364A595BLB
    BNC Right Angle PC Jack, LOW PROF BLK
    4 GHz
    364A595BL
    BNC Right Angle PC Jack, LOW PROF WHT
    4 GHz
    364A595B
    BNC Right Angle PC Jack, STD PROF BLK
    4 GHz
    364A595
    BNC Right Angle PC Jack,STD PROF WHT
    4 GHz
    364A2795B
    X-2 DUAL NC Jacks Right Angle BLK
    4 GHz
    361VH704ER
    BNC V-BITE NON THD,4GHZ REFLOW
    4 GHz
    364A2795
    DUAL BNC Right Angle PCB Jacks 75 OHM
    4 GHz
    364DI2595
    DUAL BNC 50 0HM DBL-ISOL
    4 GHz
    364S595M
    50 Ohm BNC Jack - Vertical Mount Bulkhead
    4 GHz
    364M2795FS
    X-2 DUAL BNC METAL FULL SHLD 75 OHM
    4 GHz
    361V504EFT
    BNC V-BITE W/Flange & THD 50 OHM
    4 GHz
    361V504EFT100
    50 OHM V-BITE, 100 THICK PCB
    4 GHz
    361V504ER
    BNC V-BITE For REFLOW SolderING
    4 GHz
    361V504ET
    BNC V-BITE, 50, THREADED, TFE/GOLD
    4 GHz
