The SAED pattern shows a pattern from a large grain with defect structures,since the feature of a spot pattern is just like that. If there are lots of nanocrystallins, the pattern might be a ring pattern.
magggggg发表:The SAED pattern shows a pattern from a large grain with defect structures,since the feature of a spot pattern is just like that. If there are lots of nanocrystallins, the pattern might be a ring pattern.
