Model List | |||||||||
Model Number | Input Voltage (Range) | Output Voltage | Output Current | Input Current (typ input voltage) | Load Regulation | Maxcapacitive Load (Cap ESR>=10mohm;Full load;5%overshoot of Vout at startup) | Efficiency (typ.) | ||
Max. | Min. | @Max.Load | @No Load | @Max.Load | |||||
VDC | VDC | mA | mA | mA(typ.) | mA(typ.) | mV(max) | uF | % | |
S24SP05012 | 24 (9-36) | 5V | 12000 | 0 | 2700 | 70 | ±25 | 20000 | 92.4% |
S24SP12005 | 12V | 5000 | 0 | 2695 | 60 | ±60 | 6000 | 92.8% | |
S24SP15004 | 15V | 4000 | 0 | 2680 | 60 | ±75 | 4000 | 93.3% | |
S24SP24003 | 24V | 2500 | 0 | 2688 | 40 | ±120 | 2000 | 93% |
