Parameters | Specifcations | ||
Input voltageVin (pins 283) | 15Vdc±1.5Vdc or 24Vdc±2Vdc,according to type | ||
Input current | Example for a 15Vdc,output 6000V,1mA model:inhibition mode:27mA atno load &HV=1500V:46mA at full load:260mA | ||
HVoutputVout (pin 8) | 0 to 1000V through O to4000V according to type | ||
Polarity | Fixed positive [DAP]ornegative[DAN];refer to the Selection Guide | ||
HVsetting (pins 4&6) | ·Option 1:via externalvoltage source 0/5V±0.1%at full scale,and input impedance=94kQ -Option 2:via external voltage source 0/10V±0.1%at full scale,and input impedance=187kO | ||
Max.outputcurrent lout | Limited to 110%of nominal current;referto the Selection Guide | ||
Load voltage regulation | ±0,01%of full output voltagefor no loadto full load | ||
Line voltage regulation | ±0,01%of full output voltage over specified input voltage range | ||
Residual ripple | 0,005%peak-to-peak at full load | ||
Temperature coefficient | 100ppm/℃ | ||
Output HV monitoring (pin 7) (still operating in inhibition mode) | ·Option 1:analog 0/+5Vbufferised output signal,accuracy±0.2% ·Option 2:analog 0/+10V bufferised output signal,accuracy±0.2% Output impedance=1kO风 Temperature coeffcient:100ppm/℃ | ||
Output current monitoring | ·Option1:analog 0/+5Vbufferised output signal,accuracy±2% | ||
(pin5) | +Option2:analog 0/+10V bufferised output signal,accuracy±2% | ||
(still operating in inhibition | Outputimpedance=1kQ | ||
mode) | Temperature coefficient:100ppm/C | ||
HV power ON/OFF | To disable(opened remote interlock)or enable (closedremote interlock) | ||
Operating temperature | Refer to Derating Curve | ||
Storagetemperature | -10℃to+70℃ | ||
Safeguards | ·Protected against reverse Vin +Soft start feature:the start is guaranteed with no overshoot +Auto inhibition if Tcase>75℃ +HV setting internally limited to 10.6V for the 10Vversion and to 5.3Vfor the 5Vversion |
Vout | lout/Pout | Win | Polarity | HV monitoring | former relrence | NEWHEFEHENCE |
4000V | 1.00mA/4W | 24V | 十 | 0/10V | DA24P402102-10 | DA24P4-4-C10 |
0/5V | DA24P402102-5 | DA24P4-4-C5 | ||||
0/10V | DA24N402102-10 | DA24N4-4-C10 | ||||
0/5V | DA24N402102-5 | DA24N4-4-C5 | ||||
0.50mA/2W | 24V | 十 | 0/10V | DA24P402501-10 | DA24P4-2-C10 | |
0/5V | DA24P402501-5 | DA24P4-2-C5 | ||||
0/10V | DA24N402501-10 | DA24N4-2-C10 | ||||
0/5V | DA24N402501-5 | DA24N4-2-C5 | ||||
0.25mA/1W | 15V | 十 | 0/10V | DA15P402251-10 | DA15P4-1-C10 | |
0/5V | DA15P402251-5 | DA15P4-1-C5 | ||||
0/10V | DA15N402251-10 | DA15N4-1-C10 | ||||
0/5V | DA15N402251-5 | DA15N4-1-C5 | ||||
24V | 十 | 0/10V | DAP24402251-10 | DA24P4-1-C10 | ||
0/5V | DAP24402251-5 | DA24P4-1-C5 | ||||
0/10V | DAN24402251-10 | DA24N4-1-C10 | ||||
0/5V | DAN24402251-10 | DA24N4-1-C5 | ||||
2000V | 2.00mA/4W | 15V | 十 | 0/10V | DA15P202202-10 | DA15P2-4-C10 |
0/5V | DA15P202202-5 | DA15P2-4-C5 | ||||
0/10V | DA15N202202-10 | DA15N2-4-C10 | ||||
0/5V | DA15202202-5 | DA15N2-4-C5 | ||||
24V | 十 | 0/10V | DA24P202202-10 | DA24P2-4-C10 | ||
0/5V | DA24P202202-5 | DA24P2-4-C5 | ||||
0/10V | DA24N202202-10 | DA24N2-4-C10 | ||||
0/5V | DA24N202202-5 | DA24N2-4-C5 | ||||
1.00mA/2W | 15V | 十 | 0/10V | DA15P202102-10 | DA15P2-2-C10 | |
0/5V | DA15P202102-5 | DA15P2-2-C5 | ||||
0/10V | DA15N202102-10 | DA15N2-2-C10 | ||||
0/5V | DA15N202102-5 | DA15N2-2-C5 | ||||
24V | 十 | 0/10V | DA24P201102-10 | DA24P2-2-C10 | ||
0/5V | DA24P201102-5 | DA24P2-2-C5 | ||||
0/10V | DA24N201102-10 | DA24N2-2-C10 | ||||
0/5V | DA24N201102-5 | DA24N2-2-C5 | ||||
0.50mA/IW | 15V | 十 | 0/10V | DA15P202501-10 | DA15P2-1-C10 | |
0/5V | DA15P202501-5 | DA15P2-1-C5 | ||||
0/10V | DA15N202501-10 | DA15N2-1-C10 | ||||
0/5V | DA15N202501-5 | DA15N2-1-C5 | ||||
24V | 十 | 0/10V | DA24P202501-10 | DA24P2-1-C10 | ||
0/5V | DA24P202501-5 | DA24P2-1-C5 | ||||
0/10V | DA24N202501-10 | DA24N2-1-C10 | ||||
0/5V | DA24N202501-5 | DA24N2-1-C5 | ||||
1000V | 4.00mA/4W | 15V | 十 | 0/10V | DA15P102402-10 | DA15P1-4-C10 |
0/5V | DA15P102402-5 | DA15P1-4-C5 | ||||
0/10V | DA15N102402-10 | DA15N1-4-C10 | ||||
0/5V | DA15N102402-5 | DA15N1-4-C5 | ||||
24V | 十 | 0/10V | DA24P102402-10 | DA24P1-4-C10 | ||
0/5V | DA24P102402-5 | DA24P1-4-C5 | ||||
0/10V | DA24N102402-10 | DA24N1-4-C10 | ||||
0/5V | DA24N102402-5 | DA24N1-4-C5 | ||||
2.00mA/2W | 15V | 十 | 0/10V | DA15P102202-10 | DA15P1-2-C10 | |
0/5V | DA15P102202-5 | DA15P1-2-C5 | ||||
0/10V | DA15N102202-10 | DA15N1-2-C10 | ||||
0/5V | DA15N102202-5 | DA15N1-2-C5 | ||||
24V | 十 | 0/10V | DA24P102202-10 | DA24P1-2-C10 | ||
0/5V | DA24P102202-5 | DA24P1-2-C5 | ||||
0/10V | DA24N102202-10 | DA24N1-2-C10 | ||||
0/5V | DA24N102202-5 | DA24N1-2-C5 | ||||
1mA/1W | 15V | 十 | 0/10V | DA15P102102-10 | DA15P1-1-C10 | |
0/5V | DA15P102102-5 | DA15P1-1-C5 | ||||
0/10V | DA15N102102-10 | DA15N1-1-C10 | ||||
0/5V | DA15N102102-5 | DA15N1-1-C-5 | ||||
24V | 十 | 0/10V | DA24P102102-10 | DA24P1-1-C10 | ||
0/5V | DA24P102102-5 | DA24P1-1-C5 | ||||
0/10V | DA24N102102-10 | DA24N1-1-C10 | ||||
0/5V | DA24N102102-5 | DA24N1-1-C5 |
