dongnan000
第2楼2007/08/08
LET ME TRY...
Physical Properties of Dextran
Molecular Weight and Size
Dextran fractions are supplied in molecular weights from 1 000 Daltons to 2 000 000 Daltons (1). The molecular weight of the fraction is in most cases a key property and is defined in terms of the average molecular weight Mw (2) and the number average molecular weight Mn (3).
The molecular weight distribution curve for each fraction obtained by gel chromatography offers a unique method for characterizing the Dextran fraction.
Molecular weight distribution of Dextran 10 is illustrated in Figure 2.
The designation 5, 10, etc. represents the mean molecular weight divided by 1 000 Daltons. Thus Dextran 10 corresponds to a mean molecular weight of 10 000 Daltons.
Dextran fractions behave as very flexible and extended polymers and in solution exist as an expandable coil. The molecular dimensions of some Dextran fractions are shown in Table 1.
Solubility of Dextran Fractions
Dextran fractions are readily soluble in water and electrolyte solutions to form clear, stable solutions. The pH does not affect solubility significantly. Concentrated solutions (> 50% w/v) may be prepared.
Dextran fractions are also soluble in some other solvents, notably, methyl sulfide, formamide, ethylene glycol, and glycerol. Dextran fractions are insoluble in monohydric alcohols, for example methanol, ethanol and isopropanol, and also most ketones, such as acetone and 2-propanone.
Although Dextran fractions will form clear solutions, it should be noted that the lowest molecular weight fractions 5 and 10 may, on standing, form turbid solutions, particularly when concentrated solutions are used. This effect may be delayed by boiling the solutions immediately after preparation.
Filtration of Dextran Solutions
Dextran fraction solutions can be filtered without difficulty. More concentrated solutions will require larger filters or filter series and higher pressures in order to increase the rate of filtration. Further increases in filtration rates may be achieved by raising the temperature. The dimensions of the filter system must be related to the volume and concentration of the Dextran solution used.
Viscosity of Dextran Solutions
Dextran fraction solutions exhibit Newtonian flow characteristics, that is, the flow rate is independent of shear stress.
Figure 3 shows the dependence of viscosity on concentration for Dextran fractions at 25 °C.
As Dextran is a neutral polysaccharide, the viscosity is not significantly influenced by changes in pH or salt concentration.
Colloid Osmotic Pressure of Dextran Solutions
The colloid osmotic pressure is important for many applications using Dextran. When comparing osmotic pressures, it is important that the molecules do not pass through the membrane with which they are in contact. For similar solute concentrations, osmotic pressure will be largely dependent on the molecular weight of the solute. Since Dextran is a neutral polymer with large dimensions, it will not easily permeate many human tissues and will thus maintain a favorable osmotic environment unlike, for example, saline which readily diffuses into cells and tissues.
A comparison of colloid osmotic pressures for Dextran fractions 40 and 70 is shown in Figure 4.
Specific Optical Rotation
[α]D = +195 – +201 (at 25 °C)
where [α] is the specific optical rotation measured in the sodium D line.
Below approximately 20 000 Daltons the specific optical rotation decreases with decreasing molecular weight.
Da : When nothing is indicated molecular weight units are assumed to be Daltons.
Mw : Weight average molecular weight of Dextran fractions.
Mn : Number average molecular weight of Dextran fractions.
REF:http://www.dextran.net/dextran_physicalproperties.html
欢迎您联系 东南科仪
我们可以为您提供 粘度、比旋光等物性测试方案“一站式”服务。
dongnan000
第3楼2007/08/08
LET ME TRY...
欢迎您联系 东南科仪
dongnan000
第4楼2007/08/08
LET ME TRY...
欢迎您联系 东南科仪
dongnan000
第5楼2007/08/08
LET ME TRY...
欢迎您联系 东南科仪
dongnan000
第6楼2007/08/08
LET ME TRY...
欢迎您联系 东南科仪
dongnan000
第7楼2007/08/08
LET ME TRY...
欢迎您联系 东南科仪
