【资料】技术参数 电导测试池
电化学综合讨论
  • 电导测试池(Conductivity Cell)
    型号:CON-H
    技术参数
    控温范围: 0-1200 C°
    样品尺寸 15 mm 直径 6 mm 最大厚度
    接触盘 白金圆盘, 弹簧进样
    材料构成 氧化铝 99.5 % 白金 99.5 %
    接触压力 最大到 15 N (可调)
    Gas compatibility Any reducing or oxidizing gas compatible with fused silica and allumina
    Gas connections Pipe holder in/out for 3 mm inner dia piping (viton recommended)
    Gas tightness Viton O-rings
    Orientation Vertical
    ELECTRICAL FEATURES
    Connections BNC
    Measuring configuration 2-wires connections + wire compensation
    Residual resistance <5 mOhm
    Effective wire resistance < 3 Ohm @ 25 C°
    Maximum current capability 2 A
    OPTIONS
    Gas Partial pressure of oxygen sensor mounted near the sample, vacuum option
    Mechanical pressure Variable pressure with mechanical stop for melting/softening samples
    Electrical connections Additional wiring for sensing partial voltages
    Mechanical Various mechanical measures with interfaceable instruments (expansion measures, melting/softening)
    Sample shapes Larger / thicker samples
    主要特点
    Measuring cell from Material Mates, based on more than two decades of experience in difficult measuring tasks, easily fit very different sample shapes within the spring loaded contact plates.
    Simple, repeatable measurements can then be performed on a wide range of impedances, thanks to a “wiring compensating technique” that takes care of wiring impedance without the hassle of sensing geometry on a true 4-wires configuration.
    With a maximum temperature of 1200 C°and a true “flow through“ gas path for controlled atmosphere operation the cell is suited for conductivity characterization at gas/temperature variation or high frequency EIS measures on grain to grain boundary and bulk properties.
    The measuring head has low electrical noise and good frequency behavior thanks to the short length design and the accurate shielding.
