方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名:Aggregation Kinetics of Multiwalled Carbon Nanotubes in Aquatic Systems: Measurements and Environmental Implications 作者:NAVIDB. SALEH, LISAD. PFEFFERLE, AND MENACHEM ELIMELECH (Department of Chemical Engineering, Yale University, New Haven, Connecticut 06520-8286) 摘要:The initial aggregation kinetics of multiwalled carbon nanotubes (MWNTs) were examined through time-resolved dynamiclight scattering. Aggregation of MWNTs was evaluated by varying solution pH and the concentration of monovalent (NaCl) and divalent (CaCl2 and MgCl2) salts. Suwannee River humic acid (SRHA) was used to study the effect of background natural organic matter on MWNT aggregation kinetics. Increasing salt concentrationandaddition of divalent calciumandmagnesiumions induced MWNT aggregation by suppressing electrostaticrepulsion, similar to observations with aquatic colloidal particles. The critical coagulation concentration (CCC) values for MWNTs were estimated as 25 mM NaCl, 2.6 mM CaCl2, and 1.5 mM MgCl2. An increase in solution pH from acidic (pH 3) to basic (pH 11) conditions resulted in a substantial (over 2 orders of magnitude) decrease in MWNT aggregation kinetics, suggesting the presence of ionizable functional groups on the MWNT carbon scaffold. The presence of humic acid in solution markedly enhanced the colloidal stability of MWNTs, reducing the aggregation rate by nearly 2 orders of magnitude. The enhanced MWNT stability in the presence of humic acid is attributable to steric repulsion imparted by adsorbed humic acid macromolecules. Our results suggest that MWNTs are relatively stable at solution pH and electrolyte conditions typical of aquatic environments.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
