方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
It has been shown that the swelling of poly-N-isopropyl-acrylamide (poly-NIPAM) microgel particles can be controlled by the addition of alcohols, in addition to the previously observed effect of temperature. The degree of swelling is also controlled by the amount of cross-linker within the microgel particles. At 25?°C, poly-NIPAM microgel particles collapse upon the addition of MeOH, EtOH and 2-PrOH to a minimum size and then, reswell again as the alcohol-rich region is approached. This trend was also observed for poly-NIPAM microgel particles dispersed in 2-PrOH/water mixtures upon heating to 50?°C. The particles, dispersed in either water or alcohol/water mixtures were found to be stable to flocculation between 25?°C and 50?°C.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
