方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Adsorption of bovine serum albumin on nanosized magnetic particles 作者: Z.G. Peng, K. Hidajat, M.S. Uddin Department of Chemical and Environmental Engineering, National University of Singapore, 10 Kent Ridge Crescent, Singapore 119260 摘要: Adsorption of bovine serum albumin (BSA) on nanosized magnetic particles (Fe3O4) was carried out in the presence of carbodiimide. The equilibrium and kinetics of the adsorption process were studied. Nanosized magnetic particles (Fe3O4) were prepared by the chemical precipitation method using Fe2+, Fe3+ salts, and ammonium hydroxide under a nitrogen atmosphere. Characterizations of magnetic particles were carried out using transmission electron microscopy (TEM) and a vibrating sample magnetometer (VSM). Fourier-transform infrared spectroscopy (FTIR) and X-ray photoelectron spectroscopy (XPS) were used to confirm the attachment of BSA on magnetic particles. Effects of pH and salt concentrations were investigated on the adsorption process. The experimental results show that the adsorption of BSA on magnetic particles was affected greatly by the pH, while the effect of salt concentrations was insignificant at a low concentration range. The adsorption equilibrium isotherm was fitted well by the Langmuir model. The maximum adsorption of BSA on magnetic particles occurred at the isoelectric point of BSA. Adsorption kinetics was analyzed by a linear driving force mass-transfer model. BSA was desorbed from magnetic particles under alkaline conditions, which was confirmed by SDS–PAGE electrophoresis and FTIR results. 关键词: Nanosized magnetic particles; Bovine serum albumin; Zeta potential; Adsorption; Desorption
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
