方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Thermal and osmotic deswelling of poly(NIPAM) microgel particles 作者: Brian R. Saunders and Brian Vincent 摘要: The effects of temperature and added free polymer on the swelling of poly(NIPAM)(NIPAM =N-isopropylacrylamide) microgel particles cross-linked with N,N′-methylene bisacrylamide have been investigated. The microgel particles were characterized by photocorrelation spectroscopy (PCS), TEM and SEM measurements. Particle sizes determined by TEM were invariably larger than those measured at 50 °C by PCS. SEM data suggest that dried particles have an oblate spheroid shape. The rate at which poly(NIPAM) particles collapse and swell in response to cycling of the temperature between 28 and 60 °C was examined and some hysteresis was observed. Excluded free polymer [PEG, where PEG = poly(ethyleneglycol)] also caused deswelling of the poly(NIPAM) particles at 25 °C due to osmotic pressure effects. Osmotic deswelling occurred in the presence of monodisperse PEG when the molecular weight of the latter was 1470 g mol–1. Higher molecular weight PEG polymers caused a general decrease in the extent of deswelling (at a fixed concentration of PEG).
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
