方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The surface properties of carbon nanotubes have been changed by heat treatment with ammonia to yield a basic surface or with N2 to yield an acidic surface without destroying the integrity of the nanotubes. The dispersion state of CNTs could be much improved by the adsorption of a cationic dispersant of poly(ethylenimine) (PEI) or an ionic dispersant of sodium dodecyl sulfate (SDS). Through the electrostatic interaction between components, CNTs could be successfully coated with particles of titania or alumina by colloidal heterocoagulation. A titania coating on 1.5wt% CNTs, shows the same photocatalytic properties in phenol degradation and has advantages in separation and reuse.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
