方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The temperature stability of aqueous dispersions of hydrophobic monodisperse silica particles stabilized with nonionic surfactants has been investigated. Adsorption isotherms in conjunction with surface tension measurements showed that the surfactant formed a monolayer on the surface of the particles, where the adsorbed amount depended on the molecular weight of the ethylene oxide headgroup. The temperature stability of these dispersions has been measured by a standard turbidimetric technique and visual observations in terms of their critical flocculation temperature (CFT). Parameters controlling the CFT of the individual dispersions stabilized with a monolayer of surfactant include the thickness of the steric layer, the particle size, and the volume fraction of the particles. Calculations show that the van der Waals attraction between the particles with adsorbed polymer layers increases as the temperature of the dispersion increases, and this largely accounts for the observed CFT behavior.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
