方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Titanate nanotube films are fabricated on F-doped SnO2-coated glass substrates via an electrophoretic deposition method using hydrothermally prepared titanate nanotubes as precursors. The effects of calcination temperature on the microstructures and photoactivity of as-prepared titanate nanotube films are investigated and discussed. The results indicate that the intercalated sodium ions (Na+) in the as-prepared titanate nanotubes are easily removed during the electrophoretic deposition. The phase transformation of titanate to anatase and diffusion of Na+ ions from glass substrates into films occur at 400?°C. With increasing calcination temperature, the crystallization of anatase enhances and sodium content in the films increases. At 500?°C, the tubular structure still holds and the films show the highest photocatalytic activity probably due to their good crystallization, large specific surface areas and tubular structures.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
