方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Chitosan and its various neutral pH water-soluble derivatives were investigated for dispersing single-walled carbon nanotubes (SWNTs). Chitosan (CS) can produce good dispersion of SWNTs, but only in acidic pH condition. Our two novel derivatives, O-carboxymethylchitosan (OC) and OC modified by poly(ethylene glycol) at the ?COOH position (OPEG), were able to produce highly effective debundling and dispersion of SWNTs in neutral pH aqueous solution. Atomic force microscopy (AFM), transmission electron microscopy (TEM), photoluminescence, UV?vis?NIR spetroscopy, and Raman spectroscopy confirmed that SWNTs are present as individual nanotubes in the dispersions. The solubilities of individually dispersed SWNTs in neutral water are 0.021 and 0.032 g/L for OC and OPEG, respectively, which are comparable to 0.038 g/L for SWNTs using CS in acetic acid. Further, OC and OPEG aqueous solutions (1 wt %) do not significantly lower the surface tensions (65?67 mN/m). From the Fourier transform infrared spectroscopic results, we conclude that the free electron pair in the pendant amine groups of OC and OPEG plays a vital role in finely dispersing the SWNTs; the ?NH2 contributes to the adsorption of these two chitosan derivatives on the nanotubes. Quaternary ammonium chitosan (QC), with alkyl substitution at the protonated amine, was found to be unable to disperse SWNTs; possibly cation?π interaction with nanotubes is diminished due to steric hindrance.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
